20 Most Recent Toshiba e-Studio163 Copier Questions & Answers
http://copiers.toshiba.com/support/index.jsp
Toshiba... | Answered on Jul 12, 2019
Hello
I dont know what you want to reset so i will explain how to reset the whole machine.
Please switch off the machine, while holding down the * 1+3 buttons switch on the machine, dont take off the fingers until the machine is back on.(star, one and three buttons)
Regards
Toshiba... | Answered on Mar 06, 2018
Seems that mainboard or SRAM problem...
Toshiba... | Answered on Sep 09, 2017
Driver can be downloaded at below link.
http://www.copiers.toshiba.com/support/index.jsp
If u're using usb cable, try install the usb driver 1st below proceed to install printer driver. After that, install the P3 application, which is a scanning driver.
Toshiba... | Answered on Aug 09, 2017
Toshiba e-studio162 drivers are available Toshiba Official Support
Click 'Support & Drivers'
Choose B/W Copiers
Choose e-studio162
Select the drivers for your operating system and download
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
How can I areas the maintenance light on the toshiba e studio 211
Toshiba... | Answered on Jan 21, 2017
1st. you may Replace the MAIN board.
if the problem still in
Replace the laser optical unit.
Toshiba... | Answered on Oct 24, 2016
0+8>252="0"
Toshiba... | Answered on Jun 26, 2016
Application start error.
reinstall the HDD software
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
Toshiba... | Answered on May 30, 2016
after changed one of the sensors ,the same problem-"no cassette with paper of the sieze requested is available" has happened,alway paper jam.
any ideas why?
machine:e studio0259
Toshiba... | Answered on Nov 30, 2015
Press *+1+3 and power on the machine.
Toshiba... | Answered on Oct 03, 2015
Did u select the paper size setting accordingly on the printer driver?
Toshiba... | Answered on Sep 11, 2015
hi how are you .. this is jack hear in pk..
your copier scanner strip is damage .. please change it and solve ....
the problem...(jack_pak@hotmail.com)....
Thanks
Best Regards.
Toshiba... | Answered on Dec 17, 2014
press start and 9 button simultaneously when power on.In the display LS is blinking type102 and press start button function list will come
Toshiba... | Answered on Aug 18, 2014
cause c 45 Thermistor abnormality during printing: Abnormality of the thermistor is detected during printing i think replace thermistor
Toshiba... | Answered on Jul 31, 2014
Check if scrapers are bent, paper size difference,heat roller not rotating.
Toshiba... | Answered on Jul 06, 2014
There are several error you need to know the sub code by pressing c and 8, frequently you may come across the error code C44,C97,C26
.For C44 the error clearance is "switch on the copier while pressing 0&8 AD will appear enter 400 and press start (print) button and enter "0" and press Interrupt button , switch off and on the machine .If the error code is C97 the main charger to be cleaned in drum unit, If it is C26 you need to check the scanner cable..Hope the anser.
Toshiba e-Studio163 Copier Logo
239 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
reset e studio 166
  • Office Equipment & Supplies
