20 Most Recent Samsung Digimax S700 Digital Camera Questions & Answers
If the pictures were on a memory card and you haven't done anything with the card since formatting it then you may be able to recover at least some of the pictures. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the memory card into a card reader attached to your computer and run the program.
Samsung Digimax... | Answered 15 hours ago
No. The S700 works with MMC and SD cards, which top out at 2GB.
Samsung Digimax... | Answered on May 16, 2019
you can remove the memory card from camera, and then download camera recovery program, recommended Asoftech Photo Recovery, you can download the software from
http://download.cnet.com/Asoftech-Photo-Recovery/3000-2094_4-10913438.html?part=dl-10913438&subj=dl&tag=button
Samsung Digimax... | Answered on Jan 14, 2019
Do it manually on camera or on computer.
Samsung Digimax... | Answered on Apr 01, 2015
It's the optical zoom. The motor that pushes it in and out died.
Samsung Digimax... | Answered on Oct 22, 2013
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Samsung Digimax... | Answered on May 08, 2013
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Samsung Digimax... | Answered on Aug 28, 2012
I've uploaded the user manual here UManual.
I think page 45 will help. Also look at formatting a memory card.
Samsung Digimax... | Answered on Feb 13, 2012
You can use the user manual from this link, just click HERE.
Samsung Digimax... | Answered on Sep 01, 2011
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones:
Samsung Digimax... | Answered on Aug 19, 2011
Hi Susan, and welcome to FixYa-
I have had the exact problem that you are describing, albeit a different make and model of camera. Here's how I solved my issue:
I grabbed the nearest heavy object and smashed the camera....
No, but seriously, try this:
The S700 has the standard "Scene Selector" knob on the top. Make sure that this is NOT pointed toward (set to) the "Self Timer" option. The icon for this, on the camera's body, looks similar to the "Auto" setting icon.
The S700 has 3 timer modes: a 10 second delay, 2 second delay and a "Double" mode wherein the camera waits 10 seconds, takes one picture then, after an additional 2 second delay, will take a second picture. The delay must be selected by the user and will appear in your LCD viewing screen. Prior to taking a test picture, look in the display screen to see if any numbers appear. If you see any, you know that the camera is in the Self Timer mode. Simply rotate the button on top of the camera to the "Auto" icon and you'll be all set.
Good luck, and let us know how you go!
Samsung Digimax... | Answered on Aug 10, 2011
Hi christoph8550,
Please follow the below steps :-
Make sure that you remove any memory cards from your camera and then switch on your camera.
After you have done that , you would have access only to your camera's built in memory for storing photos.
Now , try clicking a photo and see if it get's saved, if it does , then you need to format your memory card even if you feel you have it empty and then insert and check if the problem persists.
If it does not save and give you the same error , now it's time for you to format your camera's internal memory , just deleting them is not enough many times.
After you have done formatting this problem would go away for sure.
Let me know in case you have any queries.
Hope this helps ..:)
Samsung Digimax... | Answered on Jun 19, 2011
Samsung Digimax S700 Digital Camera Logo
69 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
www samsungcamera com
  • Cameras
