20 Most Recent Memorex Mega TravelDrive 4 GB USB Hard Drive Questions & Answers
get another driver download software program, google it as "drivers downloads" then try some of them for driver updates
Memorex Mega... | Answered on Jan 25, 2019
To make any Drive Work formatting is a necessary step. If you don’t do it then it will never work.
Memorex Mega... | Answered on Dec 19, 2017
you could download and install an undelete program there are many of these which are totally free to use once you have finished just uninstall it or you could just leave it on your hard drive
http://majorgeeks.com/Free_File_Recovery_d6792.html
Free File Recovery is a small and easy to use application that will help you to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital cameraclip_image001.gifmemory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
here is another yould use if you have no luck with the first
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media. hope this helps
Memorex Mega... | Answered on Dec 17, 2014
Delete your needed files off from your USB hard drive without backups left? What a pity! But, don't worry! In your case, without drive data backups, you also can try to take them all back with data recovery software.
Just follow this video to get your needed stuffs back step by step:
https://www.youtube.com/watch?v=Lqb0uxpq2mQ
Just back up everything needed well in the future.
Memorex Mega... | Answered on Nov 27, 2014
Trouble shooting steps I would probably take:
1) Power cycle the computer (unplugged), and try it again, when it is COMPLETELY booted.
2) unplug it and plug it into a different port(s).
4) Try it on a different computer (both PC and MAC, as it could be a formatting issue) (if it doesn't work, entertain the reality that I may have lost everything and may have to format the drive and/or buy a new one)
Memorex Mega... | Answered on Oct 22, 2013
Asoftech data recovery software is comprehensive recovery software for any Digital Media. It features an extremely easy interface and powerful functions that allows users to recover deleted and lost photos, music and video files from USB Drive, Pen Drive, memory cards, etc. The software works with Microsoft Windows 2000/XP/2003/Vista and Windows 7, and it's very easy to use.
http://www.asoftech.com/adr/
Memorex Mega... | Answered on Jan 17, 2013
try download this software"http://www.datadoctor.in/data-recovery-software/pen-drive-data-recovery-software.html" which recovers the password
Memorex Mega... | Answered on Aug 23, 2012
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps you
Memorex Mega... | Answered on Aug 28, 2011
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps you:
Memorex Mega... | Answered on Jul 28, 2011
You can reformat it by opening up My Computer, right-clicking on the drive, and clicking format. I recommend formatting your drive as NTFS as it will give you an option.
Memorex Mega... | Answered on May 02, 2011
Good morning!
I believe that this is what you're looking for:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Memorex Mega... | Answered on Mar 13, 2011
If you have a Windows operating system for your computer, you should be able to see the contents of the USB drive via the Windows Explorer window, but if you are having trouble locating the files, try this trick:
1. Before inserting the USB drive, find the "My Computer" icon on your desktop, and double-click it.
2. When the My Computer window pops up, make a note of all the drives listed. Each one will be assigned a different letter, for example: "Local Disk (C:)" is your "C" Drive, already located inside your computer. You probably already have a C, D, maybe E, and possibly F
3. Insert the TravelDrive into a USB port, while watching the list of drives in your My Computer window. If the TravelDrive is working properly, it will be assigned a new letter. It will probably be something like "Removable Disk (G:)"
4. Double-Click the name of the new drive, and you should be able to see its directories and contents the same way you view the rest of the files on your computer.
Memorex Mega... | Answered on Jan 11, 2011
Hi!
To see all the contents of the drive, go to Control Panel, switch to classic view and open Folder Options, then go to View and in the list, choose "Show hidden files and folders"
Hope this helps!
Memorex Mega... | Answered on Jan 03, 2011
The TravelDrive is a "plug-and-play" device, and Windows 7 supports Plug-and-Play.
So, any device-drivers are included, and will automatically be used when you connect the TravelDrive.
What problems are you having? Symptoms? Error-messages? Does the TravelDrive work in some other computer? Does any other USB device work in the USB port that you are using for the TravelDrive?
Memorex Mega... | Answered on Dec 18, 2010
you can download your memorex mega travelDrive 4 manual from this link
http://www.memorex.com/PageFiles/1180/manual.PDF
and learn well how to use hope that was helpfull
Memorex Mega... | Answered on Sep 11, 2010
the portable vault programs that come with the USB type flash drives have no give and take, you can recover the drive by deleting the files.
for the password, you need to know it. but there is a way to get an unlimited number of tries. back up all the files to a folder on the hard drive, the program will refuse to run from there but that also means the counter isnt counting. run the original and atempt the passwords. when you think you have used the max tries then delete the files and restore from your back copy and continue trying.
Memorex Mega... | Answered on Jun 10, 2010
Memorex Mega TravelDrive 4 GB USB Hard Drive Logo
47 questions posted
Top Memorex Computers & Internet Experts
Ekse
Vernon Taylor
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Traveldrive Memorex
  • Traveldrive Memorex
Most Popular Question
open drive
  • Computers & Internet
