20 Most Recent Nokia N95 Cellular Phone Questions & Answers
Here is a video which explains how to replace the screen, pretty clear.
Hope this helps
Nokia N95... | Answered on Jun 19, 2019
First thing to note is that the deleted data on the phone will remain there until something new is saved and overwrites it. This might not happen immediately but eventually, after continued use, it will.
Either connect the phone straight to a PC using a USB cable (if supplied with the phone) or take the card out and put it in a card reader attached to the PC. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Then try some photo recovery software on the PC. This should recognise the phone or card and then you can scan it using the free download of some good photo recovery software. That will show you what files still exist on the phone or card and what can be recovered.
http://www.asoftech.com/apr/
Nokia N95... | Answered on May 16, 2019
Hi! I am locked out of my phone & it is prompting me for the PUK code and I can't find this?
Nokia N95... | Answered on May 01, 2019
Power off phone. Press and hold Green, * and 3 and keep them held whilst powering on and for a few seconds after
man the code written is hard reset for n95 **** .there is a hardware problem in the cell phone you need to change the strip of ur cell phone which connect the upper and lower portion.
Nokia N95... | Answered on Mar 15, 2019
You cannot use Nokia's N95 8GB firmware with the chinese model as they use different operating systems completely.
Nokia N95... | Answered on Jul 04, 2018
How to unlock ZTE z665c for emergency call
Nokia N95... | Answered on Nov 21, 2017
There are 3 methods to format the phone
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMPORTANT: back up your phone and memory card first! ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore. note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area. Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm. Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button While holding this combination press the power button once to start the phone Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable. Then select Mass Storage mode on the phone. Once you PC has installed the Mass Storage device you can format the card from My Computer. Note: assuming Microsoft Windows XP or VISTA.
Billman87
Nokia N95... | Answered on Nov 20, 2017
First of all u move the icon of CR to folder Extra. Then create one folder in memory card. Name it according to your choice. While saving give the path of that folder
Nokia N95... | Answered on Nov 04, 2017
that is not possible .
Nokia N95... | Answered on Oct 09, 2017
i make a call to customer care of of ur service provide,,
u need to give then sim number they can help u,,,
Nokia N95... | Answered on Aug 09, 2017
the songs were not copied but the songs file was moved to a new location on his pc hence your file cabinet is now empty
Nokia N95... | Answered on May 06, 2017
Nokia N95 Cellular Phone Logo
4,224 questions posted
Popular Products
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
View Most Popular
N Nokia
  • N Nokia
Most Popular Question
zte phone unlock
  • Cell Phones
