20 Most Recent Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Questions & Answers
Great advice from medeer, I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
My refrigerator is 20 months old, just a few months past the warrentee,
Kenmore Elite... | Answered on Mar 20, 2019
you have to send model number,on some bottom mounts there is a metal striker on the door that hits the switches,sometime that gets bent back,all you have to do is readjust the striker by bending it if screws aren't loose but i don't know what kind of bottom mount you have
Kenmore Elite... | Answered on Nov 06, 2018
Good Job Nail i agree with thats a new change toward the word. Hopes you would never mind this. As i appreciate you work. You are always welcome post. The Queen Is wondering about it.
The Queen Full Episodes 2018 Mzansi Magic Online Free Video
Kenmore Elite... | Answered on Jul 13, 2018
Found this solution on another site. http://davesgarden.com/community/forums/p.php?pid=6759829
Kenmore Elite... | Answered on May 19, 2018
On one model you do the following: To get it out of the demo mode, press and hold the "up" and "set" pad for 10 seconds.
Kenmore Elite... | Answered on Apr 24, 2018
The ice could be caused by a partial thaw such as a power failure. To open bin unplug unit. Get lots of towels and a wet Vac if you have one. The use of these will become obvious shortly. Open the door and put a fan blowing on it, the same type of fan we use when it is hot to cool down. Then wait in time it will start thawing. This would also be a good time to clean it inside, you probably were putting that off. When totally thawed and dry start it up and keep an eye on it for a few days it will probably be ok. If not you have a clean unit to try some of the other suggestions.
Kenmore Elite... | Answered on Apr 16, 2018
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore Elite... | Answered on Jan 29, 2018
Been three days and you have not received reply, would go to sears customer support and they are supposed to have live support, maybe they can help.
Kenmore Elite... | Answered on Aug 03, 2017
Remove all the food from the unit and clean it with a diluted chlorine bleach solution and let dry and then do it one more time. Also get a box of baking soda and put it in the fridge to absorb odiferous smells odors
Kenmore Elite... | Answered on Jun 30, 2017
Could have a bad condensor at the motor.
Kenmore Elite... | Answered on Mar 02, 2017
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
1,245 questions posted
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
refrigerator model 795 72063 315 now
  • Refrigerators
