20 Most Recent Frigidaire Model: PHSC39EHSS Questions & Answers
Hey, I would check water filter if it has one and the water line to water valve at the back of refrigerator. I'm thinking dirt or something when they work on water problem in other unit.
Frigidaire... | Answered on Feb 07, 2018
Good Morning Edwin,
I see that you changed the motherboard in your Frigidaire refrigerator, model# PHSC3EHSS1I, due to it being full of water and would damage. I would suggest contacting your local authorized technician for further assistance. They will be able to diagnose exactly why the compressor will not start after you changed out the motherboard. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Apr 17, 2014
the water usually comes from the evaporator defrosting and the drain being plugged with ice or frozen water. try a hair dryer and defrost the frozen water and clean the drain plug and hose
Frigidaire... | Answered on Mar 18, 2010
This is a combination of problems. I have a Kenmore Elite labeled Frigidaire model 253.44513601. If you are reading this you are aware that Kemore/Frigidaire refer's are JUNK.
I have went through TWO Kenomre Elites since 2001. My lateset Fridge (bought January 2007) suffered the "E F" code.
At first I replaced the Evaporator Fan (behind freezer compartment.) This did NOT solve the problem. I then bought a new control board located under the freezer. (take off toe plate, and removes screw, the board slides out and is connected by 3 wire harnesses.)
My fridge is now running, but it has yet to get "cool." This maybe because the User Interface needs to match the control board. Not sure yet, but I will keep posted.
Frigidaire... | Answered on Jul 18, 2009
getting access to the actuator. this is the procedure;
turn off the power
Remove the drain tray it just snaps out. remove the 3 screws behind the tray. carefully lift the panel up and out. There is a short control wire connecting the panel to the frig so be careful. remove the water hose from the outlet hole and remove the ice and water module.
its very easy  The drip tray will just slide out and then you will see the screws that hold the trim in place.
to get more complete details just click the link directly and get the proper diagrams  http://appliancejunk.com/forums/index.php?topic=282.0
if you have not had the fridge repair yet here is how to get in to the dispenser to get the actuator.
Feel or look along the bottom edge of the trim on the dispenser and you will see two slots.
Use a flat blade screwdriver to pry the bottom off.
Then slide the trim up and lift it off this will give you access to the screws to replace the actuator.
Here is a place to get Frigidaire parts
please do rate the solution.thank you for using fixya.keep updated.thanks.
Frigidaire... | Answered on May 24, 2009
The LED above the Ice Off icon should be lit when the icemaker is disabled. It should be off when you want ice from the icemaker. To toggle the setting, press and hold the Ice Off touch pad for 3+ seconds. This is shown in the manual for the FPHF2399MF2 on page 14. Sears Parts Direct has the manual here: https://www.searspartsdirect.com/manual/234cu4elin-001428/frigidaire-fphf2399mf2-bottom-mount-refrigerator .
I hope this helps.
Frigidaire... | Answered on Oct 18, 2019
If new and under warranty contact supplier. If you attempt to fix while under warranty and cause further faults then you may void warranty.
Frigidaire... | Answered on Oct 03, 2019
I would say that either the filter has split or the seal where it screws into the housing has failed. I would try a new filter and seal.
Frigidaire... | Answered on Sep 23, 2019
There are a number of reasons why this might be happening. You bets bet if to call a service guy out and let them take a look at it as some things require specialised equipment to troubleshoot.
Frigidaire... | Answered on Sep 14, 2019
Frigidaire Model: PHSC39EHSS Logo
12 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
water bottom inside freezer
  • Refrigerators
