20 Most Recent Westinghouse LTV-27w7 7 in. LCD HDTV Questions & Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Westinghouse... | Answered on May 24, 2016
You have a 27 " tv.
Westinghouse... | Answered on Apr 21, 2014
HAVE A WESTINGHOUSE LTV32-6HD. HAS SOUND, NO PICTURE. APPROXIMATELY 8 MONTHS OLD
Westinghouse... | Answered on Aug 09, 2013
Only if you have an external headphone amplifier that is connected
to the TV audio out.
Westinghouse... | Answered on Sep 23, 2012
Those channels all are related in the same tuning band that most tuners have----suspect you have a bad tuner--unless you are using a box in which case suspect the box is the issue.
If the tuner is the problem there are ways around that--used a cable box set to the rear inputs (audio/video) on your set and bypass the problem.
Westinghouse... | Answered on Jun 04, 2012
Sounds like a hookup issue--what is being used for 1080 on the set?
HDMI? Component?
Westinghouse... | Answered on Apr 23, 2012
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
137 questions posted
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
no picture audio ok power cycled
  • Televison & Video
