20 Most Recent Whirlpool AWM8163 Front Load Washer Questions & Answers
Please check on the link of the official site of Whirl pool.
Whirlpool Help
Whirlpool... | Answered on Dec 26, 2017
if everything else works its probably the circuit board. expensive to replace.
Whirlpool... | Answered on Nov 11, 2013
Hello Kathryn - try this link to the Whirlpool website
http://www.whirlpool.co.uk/buy-accessories-1/washing-%26-drying-accessories-2/cleaning-products-3/102012020/
I hope this helps
Whirlpool... | Answered on Jul 27, 2013
The possible fault could be due to the failure of the heating coil, failure of the control panel or the output drive to the heating coil or it can be one of a loose connection joint of the wiring to the heating coil. You need to recheck the selected program and then check the wiring to the coil. It is important to understand the working of a continuity tester to check the line and the coil which should address the fault. If there is no output from the board then it might be fault of the drive output or the loss of output from the processor which might need tracing of the voltage to the heating coil output. .
Whirlpool... | Answered on Jun 03, 2013
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
Whirlpool... | Answered on Jan 21, 2013
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Whirlpool... | Answered on Apr 06, 2012
Whirlpool AWM8163 Front Load Washer Logo
55 questions posted
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
f h displaying
  • Washing Machines
