20 Most Recent Whirlpool LGV4634JQ Gas Dryer Questions & Answers
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
Whirlpool... | Answered on Mar 01, 2015
does the igniter glow? If not check for 110 volts at igniter .
Check for 110 volts at gas valve if no volts check hi limit thermostat , operating thermostat, safety switch on motor,
the coils on the valve & the timer contacts that feed the voltage to the burner.
Whirlpool... | Answered on Jun 02, 2014
What is the problem with your unit?
Whirlpool... | Answered on Jan 24, 2013
check here for heat solutions , they have test directions also http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Whirlpool... | Answered on Aug 15, 2011
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Whirlpool... | Answered on Jul 14, 2011
have you checked the gas connection?
Whirlpool... | Answered on Jun 26, 2011
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Whirlpool... | Answered on Jun 12, 2011
heatman101
Whirlpool... | Answered on May 18, 2011
This is usually the coil packs that cause this. Replace them and should be fine.
Whirlpool... | Answered on May 02, 2011
Gather your tools and follow directions listed.
First start the machine.
Infront there is a little sqaure plastic cover. pop it off and see if you see a glow. If not then grab a quater inch nut driver and take the big black cover off the back. Of course unplug the unit. There you will see a little skinny white fuse. Take one wire off and test continuity. If yes then go to the igniter and check voltage. If not then then the fuse is bad and needs replaced. You can not reset it. Further assistance I am by the phone 877-293-1739 - 574-232-8040 I have the part instock can ship tomarrow for around 13$
Whirlpool... | Answered on Mar 13, 2011
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer
Whirlpool... | Answered on Jan 24, 2011
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Whirlpool... | Answered on Jan 15, 2011
when it's in auto all it does is the heat comes on,reaches temp. then the heat shuts off,when the heats off then the timer advances,when the heat comes back on the timer stops.pop off the plastic cap on the left hand side of the front panel,put clothes in the dryer and run it,after 15 to 30 minutes look in the hole in the front panel and make sure the flame is still liting,also did you clean out the duct that the lint filter slides into.remove the vent line and if that's a long run blow it out with a leaf blower,i had one guy say his vent line was clear and he used a leaf blower and blew out a birds nest,then unplug the dryer,remove the back panel,on the left side take out the four screws and remove the duct and clean that out and the blower wheel,also remove the thermostat on the blower wheel housing and look at the back of it,if lint is stuck on it clean it off and put it back in and try that.also you said you changed out the gas coils,when you removed the out coils on the large coil there's a spacer that goes on the post and sometimes when you remove the coil it gets stuck inside the old coil or if after running the dryer for like 20 to 30 minutes and the flame doesn't lite you have bad gas coils,when they heat up they fail when they are going bad and that will stop the timer from advancing.let me know what you find and if i can help with any questions let me know
Whirlpool... | Answered on Jan 08, 2011
heatman101
Whirlpool... | Answered on Jan 03, 2011
There are quite a few things to check on a gas dryer.
  1. Gas valve coils
  2. Igniter
  3. Flame Sensor
  4. Thermal Fuse
  5. High Limit Thermostat
  6. Cycling Thermostat
Here is a video to walk you thru the process of doing the diagnostics on the dryer to find the failed component.
Whirlpool... | Answered on Dec 31, 2010
Try this link it should help Typical igniter replacement You can also enter your model # there and get diagrams and illustrations of your specific model.
Whirlpool... | Answered on Dec 27, 2010
heatman101
Whirlpool... | Answered on Dec 13, 2010
Whirlpool LGV4634JQ Gas Dryer Logo
100 questions posted
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
find
  • Dryers
