20 Most Recent Canon LASER SHOT LBP-2900 Printer Questions & Answers
try print spooler services and if not running... restart spooler services.
Canon LASER SHOT... | Answered on Sep 16, 2019
I get this error on a Canon Laser LBP5050. I have replaced all the cartridges to no effect.
Canon LASER SHOT... | Answered on Sep 05, 2019
I have a same problem .... somebody help us. :(
Canon LASER SHOT... | Answered on Jul 15, 2019
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Canon LASER SHOT... | Answered on May 09, 2019
press resume button at least 4 seconds
The Canon Laser Shot LBP2900, does not use ink(liquid), it uses a Cartridge called "Toner" which contain "black powder" form in the cartridge capsule.
If you wish to check the Toner Level, refer to this guide @ http://support-in.canon-asia.com/contents/IN/EN/8100134600.html
Hope it helps.
Canon LASER SHOT... | Answered on Apr 02, 2019
You can follow the following steps to take a test page from LBP2900.
1) Goto --> Start --> Control Panel-->Printers and Faxes.
2) You can see that Printer name inside the above folder. Right Click on the same and click on Properties. Now you will be in General Tab.
3) You can see the "Print Test Page" Button on the same. Click on that you will get the test page.
Canon LASER SHOT... | Answered on Mar 12, 2019
J AI UN IMPREMANTE CANON 2900APRES L INSTALATION ELLE S AFFICHE UN CODE E1000000 J AI FAIT BEAUCOUP D ESSAY POUR ARRIVER A RESODRE SE PROBLEME MAIS J AI PAS ARRIVE JE DEMANDE AIDE ET MERCE BEAUCOUP
Canon LASER SHOT... | Answered on Mar 02, 2019
aser scanner unit error.
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Canon LASER SHOT... | Answered on Feb 25, 2019
Now official drivers from CANON for lpb2900 win7 x64 !
http://fr.software.canon-europe.com/software/0038030.asp?model=
Canon LASER SHOT... | Answered on Feb 20, 2019
my canon laser shot LBP 2900 gives blank paper after refilling of cartreage
Canon LASER SHOT... | Answered on Feb 18, 2019
this printer has a usb interface can you see an axis 1650 usb to ethernet server box attached to the usb cable that is attached to the printer ?
would check power to the usb to ethernet server box see photo inserted of what it looks like !
Maybe the power has been disconnected or the ac-dc adapter has gone faulty .
If it has power may be try removing power from it for 20 seconds and then re plug in and then test by printing to printer.
check print server has valid ip address.
also check dhcp server on network has not got printer servers ip address in its lease range. check also that printer server's ip address is static and not being set automatically.
if printer server is ip address try going to dos prompt on p.c. and type in ping {ip address of server} eg c:> ping 192.168.0.2
press Enter key
should get a reply 4 times
Canon LASER SHOT... | Answered on Jan 12, 2019
The Canon LASER SHOT LBP-2900 only has a usb port to my knowledge. If it is saying incorrect port you can try to right click on the printer, click on printer properties, click on ports and then select USB001 virtual port. Good luck.
Canon LASER SHOT... | Answered on Dec 19, 2018
you can get its driver in hp website
Canon LASER SHOT... | Answered on Dec 02, 2018
The problem is with the printer head which is normal in Laser Printers. Try cleaning the printer head with a cotton cloth and it'll resolve the problem a very large extent.
Canon LASER SHOT... | Answered on Sep 05, 2018
Call cannon tech support sounds like your computer port is not set up for the printer need to program it
Canon LASER SHOT... | Answered on Aug 15, 2018
Canon LASER SHOT LBP-2900 Printer Logo
1,267 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
test page briefly demonstrates printers
  • Office Equipment & Supplies
