20 Most Recent Frigidaire FRS3R5EMB Side by Side Refrigerator Questions & Answers
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Frigidaire... | Answered on Sep 18, 2019
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Frigidaire... | Answered on May 27, 2019
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper thats bad.
part# is 241600906
Frigidaire... | Answered on Feb 10, 2018
I would call Frigidaire. Ask if they have a remedy. Most likely there are others with this model having same problem
Frigidaire... | Answered on Nov 19, 2017
those clicking sound comes from the solenoid
this problem needs to be checked by a qualified technician
Frigidaire... | Answered on Oct 27, 2017
fixya doesnt sell products or replacement parts search on line using make and model for part or notify manufacturer for a parts distributor in your area
Frigidaire... | Answered on May 18, 2017
Did you check the motor and/or damper mechanism that directs cold freezer air into the refrigerator portion. If that is messed up the freezer is ok but fridge is ng. Also look at door seals for proper sealing.
Frigidaire... | Answered on May 05, 2017
Hello Leslie176,
They are called reverse twist bolt/screw extractors..
The prettiest I have ever seen came from EASTMAN restoration products..
You are looking for the variable sized set that fits into an ordinary soct wrench with... EXTENSION (should get you into the filter housing...
ELSE
You will hhave to replace the whole Filter housing
IRWIN HANSON Hex Head Multi Spline Screw Extractor Set 25 Piece 53227 Hex...
Check out the eBAY version
(you don't need QUALITY STUFF for plastic
Hanson AHN53204 7 32 034 Hex Head Multi Spline Screw Extractor Bulk NEW...
Frigidaire... | Answered on Apr 13, 2017
I have had the same problem, and can't fix it at the refrigerator. You need an presure reglator or bladder on your hot water heater. when you have to much pressure it usually starts causeing problems at the hot water heater with leaks and works its way down in other areas of the house. We put a regulator at our water meter at first and it did not help.. if it is leaking at your fidge, you may want to check other appliances.
Hope this helps
Frigidaire... | Answered on Apr 04, 2017
What is the water line that you would like to install is it attaching to the refrigerator your question or is it a water line that goes under the refrigerator and to the dispenser or the ice maker? Is the model number of the refrigerator correct within your post?
Appliance 911 Sea Breeze
Frigidaire... | Answered on Sep 01, 2016
Hello Chuck, thank you for your post!
From the information you have provided you are receiving low water pressure at the dispenser on your Frigidaire refrigerator. This could be due to a dirty or clogged filter and I would check to see when you last replaced it. I have researched model FRS3R5EMB and show the water filter is part number WFCB.
If you have changed your filter within the past six or nine months the low pressure could be due to an obstruction within the water line or an issue within the dispenser. Since it could be anyone of these underlying issues I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. I hope that this information is helpful to you. -Matt
Frigidaire... | Answered on Apr 19, 2016
Hello Gladys, thanks for your submission!
I understand that your Frigidaire refrigerator is not sealing properly. You could be experiencing an issue with the gasket or the hinges. I would suggest checking the door hinges to assure that they are secure in position. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the refrigerator. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. I hope that this information is helpful to your repair. -Matt
Frigidaire... | Answered on Apr 11, 2016
Sure you can just click Here=> FRS3R5EMB You also can find wiring diagrams and all models on this=> Page and on this page everyone can find all manuals for Frididare Products here=> Frigidare Product Manuals
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze Sea Breeze
Frigidaire... | Answered on May 11, 2015
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
959 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidaire refrigerator making beeping
  • Refrigerators
