20 Most Recent Frigidaire FRU17G4JW Refrigerator Questions & Answers
First, best guess is you need a new door gasket. Before replacing it, try cleaning the gasket thoroughly with a good brush and spray cleaner with bleach (for any mold growth)
Frigidaire... | Answered on Dec 13, 2017
part worn from use --check the hinge bolts first --the hinge pins --door gaskets and or not level
Frigidaire... | Answered on Jul 21, 2017
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Frigidaire... | Answered on Jan 16, 2017
check shelving and stock in door not stopping door closing. Check hinges tight and complete (sometimes have a self limitting plastic stopper that breaks, allowing weight of door to pull itself open)
Frigidaire... | Answered on Apr 05, 2014
Frigidaire FRU17G4JW Refrigerator Logo
32 questions posted
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
freezer door stay shut
  • Refrigerators
