20 Most Recent Samsung CLX-3160 All-In-One Laser Printer Questions & Answers
The scanner may have a locking lever that locks the scanner head so you can transport it without damaging the scanner head.
Locate the locking lever and unlock the scanner head.
Samsung CLX-3160... | Answered on Feb 02, 2019
Replace black developer unit.Toner cartridge is merely a toner tank
Samsung CLX-3160... | Answered on Apr 08, 2016
This means paper is jammed inside the fusing unit.open the back cover and clear the jam
Samsung CLX-3160... | Answered on Oct 02, 2015
dear
click on START click on PRINTER AND FAX, on the new window right click on the printer icon select PRINTING PREFERENCE, on the new window select GRAPHIC, at color mode select GRAYSCALE. then click on APPLY.
the printing on the side edge of page is related to the application from where you haven given the print command. reinstall that application or setting to be changed.
Thanks.
Samsung CLX-3160... | Answered on Dec 31, 2014
check whether bthe devoloping roller of black colour near the drum is full of toner or not. there is a steel doctor blade at the top of dev.roller. the edge of that roller may blocked with toner solids. clean the doctor blade.
Samsung CLX-3160... | Answered on Oct 25, 2013
open back cover,remove 4 screws of fuser,standing at the back of printer on your lhs on the fuser there is a lock,pull lock towards right and fuser should come out.
Samsung CLX-3160... | Answered on Sep 15, 2013
Remove the fusing unit and clean the upper and lower fuser roller.
Samsung CLX-3160... | Answered on Apr 04, 2013
CHECK
Printer is connected and power ON
In panel contro
go to Printers
choose Samsung Clx rigth click
unmark the check Use printer offline
Try printing a test page
rigth click Properties
click on
Print test page
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Samsung CLX-3160... | Answered on Feb 04, 2013
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
Samsung CLX-3160... | Answered on Feb 03, 2013
Samsung CLX-3160 All-In-One Laser Printer Logo
Popular Tags
127 questions posted
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
samsung clx 3180 printer showing
  • Office Equipment & Supplies
