20 Most Recent Kyocera FS-2000D Laser Printer Questions & Answers
press manu button then go to service then press right errow key goto status page press double enter it will print around 5 or 6 page in second page in down you can find the serial number or else see the back side of the printer it should stikared.............
Kyocera FS-2000D... | Answered 3 days ago
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Kyocera FS-2000D... | Answered on Nov 01, 2019
F000 is a panel communication error... update firmware... firmware as far as i know isnt available to the public... contact kyocera
Kyocera FS-2000D... | Answered on Jul 29, 2019
Error Code 6000 is fuser code, you need to replace the fuser unit, make sure there is no paper stucking there first!
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Kyocera FS-2000D... | Answered on Jun 18, 2019
It is calling for a maintenance kit.
Kyocera FS-2000D... | Answered on Feb 26, 2019
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Kyocera FS-2000D... | Answered on Nov 28, 2018
I had the same problem. Pull the Fuser and check Conector.Sometime pieces of paper inside the Conector raises an error.
Please Rate .
Kyocera FS-2000D... | Answered on Sep 28, 2018
Your machine has a FIRMWARE problem. You must call a Copystar or Kyocera Technician to resolve .
Kyocera FS-2000D... | Answered on Aug 24, 2018
Are you using manufactures toner, my guess are it is after market toner or not seated correctly, or the toner cartridge has a busted gear, either way.. try a different toner cartridge. 7000 error indicates the toner motor cant turn. the 0165540 is the page counter;
Toner motor lock error
A motor over-current signal is detected
continuously for 5 seconds since the
toner motor is activated
;) hope this helps
cheers
Kyocera FS-2000D... | Answered on Jun 11, 2018
7410 is an error (all numbers following : is the number of pages printed.
- indicating the Drum Unit is not installed properly or you have a defective curcit board. Tyoically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmaly on the drum which is loacted behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
I hope this is helpful,
Shawn
Kyocera FS-2000D... | Answered on May 23, 2018
You probably have a network card called a IB-30 installed. You will need to reset this card by changing the jumper from is original position to the next one. This will restore the original factory settings, there are only one jumper on the card. If you still have the CD your IB-30 came with it will explain to you under troubleshooting how to restore the factory defaults.
Kyocera FS-2000D... | Answered on Nov 10, 2017
its probably on the developer roller look at it as you spin the roller you should see a darker than normal area wipe the roller with a dry cloth until you no longer see it if you are turning it the right way no toner will come out the roller will have a thin even coating of toner on it or try cleaning the charge roller on top of the drum unit it should be 1 of the 2 these machines need to have the oem toner
Kyocera FS-2000D... | Answered on Sep 08, 2017
I did the same for a kyocera TA 420 showing F00 system error OFF
Kyocera FS-2000D... | Answered on Jul 25, 2017
that indicates an imperfection on a roller. could be fuser, dv unit, drum, etc... how far apart are the smudges center to center?
Kyocera FS-2000D... | Answered on Feb 07, 2016
Turn the printer off. Pull the paper cassette out and push down the green tab down to see if there is any paper jam inside. put the cassette back in and turn the printer on. Worked on my kyocera FS - 1370 DN.
Kyocera FS-2000D... | Answered on Nov 26, 2015
The drum is not pushed fully into the machine.Open the waste toner container door and gently push all units into the printer.Then turn off the printer at the wall.When you power back up the printer should be back to normal.
Kyocera FS-2000D... | Answered on Jul 11, 2015
chek motor
Kyocera FS-2000D... | Answered on Jul 08, 2015
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
Kyocera FS-2000D... | Answered on May 19, 2015
http://usa.kyoceradocumentsolutions.com/americas/jsp/Kyocera/contactus.jsp
Kyocera FS-2000D... | Answered on Mar 04, 2015
Kyocera FS-2000D Laser Printer Logo
264 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
call service f000 error
  • Office Equipment & Supplies
