20 Most Recent Kyocera FS-4000DN Laser Printer Questions & Answers
Once you have installed and setup a multi-tray printer you might like to try to print a document to different printer trays. Open a word document and create a two page document.
  • Select your new printer under file->Print (if it's not the default)
  • Click the page layout tab
  • Click the small triangle at the bottom right
  • Open the page setup dialog box and click the page Paper Tab
  • Choose a tray for the first page and other pages. Close the dialog box and print.
Kyocera... | Answered on Sep 28, 2019
make sure dial on front of cassette matches paper size in cassette
Kyocera... | Answered on Jun 13, 2019
no because its a feed source for special paper it wants you to verify what you have loaded
Kyocera... | Answered on Apr 10, 2018
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Kyocera... | Answered on Feb 27, 2018
under the front of the cassette on the bottom is a white catch if you pull it towards you the paper will spring up. more then likely it is not automatically getting pushed when you put the cassette in.
if this is not correct if you take the cassette out and look in where you took it out of there should be a arm hanging down just left of center that is the paper out sensor arm of that is broken it could be your problem also
Kyocera... | Answered on Sep 21, 2017
according to my reading, a flashing power lights indicates a problem you can solve on your own. while a error like you typed would mean something that you cannot resolve without help. a problem like a bad controller, or a bad chip. maybe a eeprom issue.
If Call service appears, turn off the printer, disconnect the power cord, and contact your service technician
Some errors cause the alarm to sound. To stop the alarm, press [Cancel].
#### represents a mechanical error (#=0, 1, 2, ...). Call for service. The printer does not operate when this message is displayed. The total number of pages printed is also indicated, e.g. 0123456.
This woiuld mean you printed 53103 pages with that printer before the error occurred.
Good Luck
articale found here
http://www.manualowl.com/m/Kyocera/FS-4000DN/Manual/166388
Kyocera... | Answered on May 19, 2016
If the spot repeats it self down the page in a repetitive mark the same distance each time you have a build up or scratch on the drum or fuser roller. If the spot is about 2.5-3 inches appart each time it is the fuser roller. If it is more like 5 inches apart each time it is the drum.
If the spot looks more like a wet spot and is about 2 inches apart then you may have a build up on your developer mag roller. let me know if you need more help.
I think that is a phone number? The error codes are listed here.
http://www.officeimagingsystems.com/id170.html
Kyocera... | Answered on Feb 11, 2016
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Kyocera... | Answered on Dec 02, 2015
Refer to troubleshooting in the user manual for an explanation of the error and put here if you cannot solve it
Kyocera... | Answered on Jun 26, 2015
Check where the waste toner bottle is, and if it's like the FS2000, the drum unit can be pushed back in from where the bottle attaches to it.
Error should then go when you close the lid back down
Kyocera... | Answered on Mar 01, 2015
This error code indicates a problem related to paper cassette lift mechanism. First thing that you will need to check is, if the printer makes some strange noises at initialization, when the printer is trying to lift the paper inside cassette. You can verify if the lift mechanism on the printer is ok, by removing paper cassette and press the 3 small white switches on the left of printer. At this moment the printer is trying to lift the cassette and you will see a gear that rotates on the right side of printer. Also verify if the GEAR LIFT Z64 is intact by opening the gearbox(the big one from the gears from the right side of paper cassette). This gear is cracked in most cases. Replace it.
Kyocera... | Answered on Jan 29, 2015
press drum unit
open left door and push drum inside.
Kyocera... | Answered on Jan 14, 2015
Open paper tray, locate the feed roller (small rubbery wheel) and moisten a cloth. Gently clean the roller to remove build up of paper dust from it.
Also worth using is some "anti static foam cleanser" on the cloth to help deep clean the rollers, or the pre-moistened "Screen wipes"
Also check there is nothing blocking hte paper path, remove paper cassette, and toner catridge (and drum if I recall correctly) and see if you can feed a sheet of paper MANUALLY from tray up into the "imaging chamber" where the toner lives. If this feels too stiff, there could be an obstruction in the way, fragment of paper scrunched up after a REAL jam, or fault sensor arm.
If you find something and can remove it, reassemble, and test
Kyocera... | Answered on Dec 10, 2014
first try the default pass word of user name:Admin pass:Admin or Admin00
Kyocera... | Answered on Aug 06, 2014
The error is for the drum unit, it may just need reseating or changing. The best thing is to take it out, give it a clean and reseat it. Hope this works for you.
Kyocera... | Answered on Jun 11, 2014
Call service 2000 main motor error
Kyocera... | Answered on May 31, 2014
pull the toner and developericon1.png (they come out as one unit unless you delibrately seperate them) out of the top of the printer. Open the side door on the print and remove the waste toner bottle. You'll see a gray button above where the bottle was. Push the button and pull the drum out about a half and inch. Push back in firmly until it clicks. Reinstall bottle and reinstall toner and developer. Should work from there, but you may have to power off, then power on.
Kyocera... | Answered on May 26, 2014
Call the Kyocera hotline they have technicians you can speak with over the phone who can help you.
You may contact Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482
Kyocera... | Answered on May 19, 2014
Kyocera FS-4000DN Laser Printer Logo
146 questions posted
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
gggg
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
kyocera fs 4000dn showing install
  • Office Equipment & Supplies
