20 Most Recent Mitsubishi WD-57734 57" HDTV Questions & Answers
your color wheel is going out. order a new one and come back to me I will walk you through the process of replacing it
Mitsubishi... | Answered on Nov 28, 2013
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Mitsubishi... | Answered on Apr 25, 2013
what cause the white and black spots
Mitsubishi... | Answered on Jan 15, 2013
If you keep blowing a fuse, you have some sort of amperage overload. Is this a fuse on the television or one in your home? If it's in your home, find out what else is on the circuit and perhaps find anothe place to plug some of the items in.
Mitsubishi... | Answered on Oct 07, 2012
If brand and model number here are correct:
set should have one or more lights on and or blinking.
suspects in order are:
Lamp
Ballast
Excessive dirt or dust inside set on fans and airflow paths
Mitsubishi... | Answered on May 16, 2012
Consider changing the lamp--only way to know if it is the trouble or not.
Mitsubishi... | Answered on Apr 28, 2012
if you do not have a hdmi output, the source has a usb to hdmi adpater, simple connection.
Mitsubishi... | Answered on Feb 04, 2012
you should be able to get the ballast from www.tvrepairworld.com if you dont see it hit the contact button to leave an email they respond quickly.
Mitsubishi... | Answered on Oct 27, 2011
The ballast board can be found to the right of the light engine on this model. Its the board from which two thick red wires go to the lamp compartment. Its not that hard to replace it if you manage to locate it but you should excercise caution as this is a high voltage circuit and can cause serious bodily harm if you are not careful. I will give you the replacement instructions, but first we need to find the replacement board online. If you can get me the part number off the one in your set, I can get you the link to the replacement. It is advisable to look for parts using part number because there are often 4 to 5 different versions of the same board available online and the part number is the only way to ensure that you get the correct version of the part.
Mitsubishi... | Answered on Sep 19, 2011
ebritton..had same issue with its bigger brother the wd65733..white spots and black specs..started out as 2..with in 2 weeks hundreds and hundreds of them.. I RESERCHED ONLINE IN MANY FORUMS..concluded it's the dlp chip .. IT'S LOCATED ..on the back of the circuit board inside the light engine assembly.....i found tvbservice on ebay had the chips in stock...mine was 300.00 ..IT WAS VERY EASY TO REPLACE...just a phillips screwdriver and a small flat blade screwdriver to remove the dlp chip itself....just make notes on exacty where the screws come out of to save you time..there is a thin metal fan assembly attached to the circuit board..remove it and un plug about 8 harness plugs...again take notes..draw pictures...so you dont plug them in wrong..TAKE THE SCREWS OUT OF THECIRCUIT BOARD AND HEAT SINC...THERE IT IS...vaccum all the dust off the board and heat sinc,,fab ect...handle the metal fan assembly with care..it bends easisly and may hit the fan blades when reinstalling it..trust me on this lol...had to take it off and straighten it up
Mitsubishi... | Answered on Sep 13, 2011
If it's not the inverter cable that has the problem then the screen is damaged/broken on the inside. Have it checked by a qualified technician or you might cause complicated issues if you do it yourself.
Mitsubishi... | Answered on Sep 11, 2011
hi; its a dead pixel you cannot remove that, if it has a warranty try to return it to the store, if not that's a big problem the only way is to replace the LCD screen, that's the expensive part of the LCD TV. its the one factor be checked when buying an LCD TV or LCD monitor. thanks,.........try to help me too by rate........
Mitsubishi... | Answered on Sep 07, 2011
You need to have the Optical unit Block also known as the Light Engine Replaced.
PTS rebuilts them 1-800-844-7871
Encompass Parts Distibution list Part# 938PO75040 Price before core refund is $1,490.00
core fee refund is only $300.00
Mitsubishi... | Answered on Jul 04, 2011
The lamp is most likely needing replacement. Replaceing the lamp is a very easy proceedure on that model.I am pasting a pic where the lamp cover is located on rear cover. Remove the screw and the lamp is behind the lamp door.
Mitsubishi... | Answered on Jun 08, 2011
Mitsubishi WD-57734 57" HDTV Logo
59 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
tv hundreds
  • Televison & Video
