20 Most Recent Sony BRAVIA KDL-46W3000 Television Questions & Answers
I am sorry to say that the LCD panel is bad.
Sony BRAVIA... | Answered on Feb 08, 2018
I would bet on it being a panel issue, you can try a new t-con but I don't think its going to correct it, may be time to buy a new set
Sony BRAVIA... | Answered on Nov 29, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony BRAVIA... | Answered on Jun 05, 2017
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Sony BRAVIA... | Answered on Mar 24, 2016
Contact the authorized service center for Sony.
Sony BRAVIA... | Answered on Jul 28, 2014
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to many popular brand TVs are given with screen-shots.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Sony BRAVIA... | Answered on Jun 21, 2014
the player is plugged in tv at video out? or am i mistaking youre explanation?
try using a scart cable it should be much better with it and not with rca connectors
Sony BRAVIA... | Answered on Mar 10, 2014
The outputs of your VCR/DVD player should be plugged into the audio and video inputs of your TV.
Sony BRAVIA... | Answered on Mar 09, 2014
U might need a new bulb.
Sony BRAVIA... | Answered on Jan 01, 2014
It sounds to be a back-light fault. Check the backlight inverter board, and back light. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Sony BRAVIA... | Answered on Nov 30, 2013
This is a semi-skilled work. Just visit this site [Electro-help] for detail description about this repair. Type in 'electronicshelponline.blogspot' into your browsers' search page, and click search. Pull up older posts there. Sometimes, ads associated by each post might give you deatils of component availability too. It is a blogspot site, in English language.
Sony BRAVIA... | Answered on Jun 25, 2012
Sony BRAVIA KDL-46W3000 Television Logo
78 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony kdl46w3000 repairs
  • Televison & Video
