20 Most Recent Toshiba 42LX177 42 in. LCD HDTV Questions & Answers
Its a failing LCD driver, not a lot you can do about it unfortunately, eventually it will get worse. Usually lines or dots are a bad driver board, but sometimes its also a bad flex cable on the LCD. Being 2 years old you probably don't have warranty, but if you do have extended warranty file a claim now, its only going to get worse, and there is no quick or easy fix.
Toshiba 42LX177... | Answered on Jan 02, 2018
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Toshiba 42LX177... | Answered on Feb 02, 2014
You have to activate the closed caption option on your charter cable box. Power off your cable box and immediately push the menu button. A menu should appear where you can toggle captioning on/off. Good luck!
Toshiba 42LX177... | Answered on Jan 31, 2010
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Toshiba 42LX177... | Answered on Jul 07, 2009
Contact Toshiba directly to request it.
Toshiba... | Answered on Oct 15, 2019
bad high power board or main control board
Toshiba... | Answered on Oct 10, 2019
go into set up and choose tv air then channel search make sure you have an antenna connected for free tv
no internet functions try using a smart DVD player for roku accessories
amazon or ebay with model number or RCA universal remote
Toshiba... | Answered on Oct 08, 2019
If u need to see online on usinig internet on your pc it is easy. For solution check the below link >>> http://w.atch.me/3qny1s
Same issue here. I kept plugging in the TV and it would flash the logo and go black. I disconnected the LED line from the power board, plugged the TV back in and the LED's all lite up and got great picture. Turned it off and on a few times with the power switch with no problem. Left it alone about an hour, came back, got the same symptoms all over again, Flash then nothing.
I changed out the Power Supply board....same issue, Flash of logo and black screen. Probably going to heave ho the set.
Toshiba... | Answered on Oct 05, 2019
You might have gotten a magnet close to it but you can't fix it if you did that
Toshiba... | Answered on Sep 29, 2019
check input or source settings if ok check picture setting
Toshiba... | Answered on Sep 28, 2019
Toshiba 42LX177 42 in. LCD HDTV Logo
Popular Tags
11 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
closed caption
  • Televison & Video
