20 Most Recent Jazz DV-179 Digital Camera Questions & Answers
The reason that the video is not playing is because the video uses certain "codecs" to decode the video. (It is basically a way that the computer interprets how to display the video on your screen.)
You need to install a good codec pack so that you can play all formats of video and/or audio.
I recommend using K-Lite Mega Codec Pack. It plays everything from Windows Media (AVI) to Quicktime files and just about everything in between. This is a very widely-used and popular codec pack. It also comes with a much simpler version of Windows Media Player. (It shows as an older version...and even looks like an older version, but it is only based on the older version as it honestly worked much better than newer versions.)
Here is the link.
(Click HERE to download the codec pack.)
Just use the DEFAULT installation. Don't change anything. There is no need to. Once it is installed, it will use the version of Windows Media Player that I just mentioned by default.
But if you still wish to use version of Windows Media Player that you currently have installed, then you may feel free to do so. It will still play videos using the same codecs that were installed by K-Lite. (All A/V programs will use the codecs.)
Another player I have recently found is GomPlayer. Very nice interface. Clean and easy to use. Install K-Lite and try out GomPlayer if you like afterwards.
HERE is a link. According to the site, you may not have to install any other codec packs after installing GOMPlayer. That may or may not be true. It IS OK if you install both.
Good luck. Let me know how it goes. :)
Cyryl
Jazz DV-179... | Answered on Jul 17, 2019
You will need t have a DVD burner software like Nero Burning ROM, ROXIO DVD creator etc., You should then install the same and select the Movie DVD option, drag and drop files into the burn list and burn them to a DVD. If you want more help please let me know once you have obtained a DVD burner software and I will guide you further.
Sai.
Jazz DV-179... | Answered on Jul 09, 2019
As 'it' says, the drivers are not compatible with your OS.
Jazz DV-179... | Answered on Aug 01, 2017
On paper those batteries are both the same. There are some subtle differences. Without using an amp meter on your chair, it is not possible to say if things have changed on the chair that cause it to pull more current out of the battery. Motor wear, gear and bearing/axel lubrication can affect the amperage that the chair needs to have. This can adversely affect the battery discharge rate.
Jazz DV-179... | Answered on Mar 25, 2017
Flat battery / corroded battery ?
Jazz DV-179... | Answered on Mar 22, 2016
This should work as long as you have the correct converter ring for the camera.
Jazz DV-179... | Answered on Jan 08, 2015
before you can download pictures, you should install the software that came with the camera. On the CD are not only drivers for all known operating systems, but also the software, needed for the computer ro recognise the camera and to stream the pictures to the computer.
If you don'e have a CD anymore, try the website from the firm where the camera came from. Or use software like lightroom, gimp or Flickr
Jazz DV-179... | Answered on May 22, 2014
I have had success with this... Download Asoftech Data Recovery program
http://www.asoftech.com/adr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Next" and wait for it to do it's magic.
Jazz DV-179... | Answered on Aug 27, 2013
Jazz DV-179 Digital Camera Logo
399 questions posted
Top Jazz Cameras Experts
Thomas F. Schneider
Ekse
Phil Whisenant
Phil Whisenant
Are you a Jazz Camera Expert? Answer questions, earn points and help others
View Most Popular
Jazz Cameras
  • Jazz Cameras
Most Popular Question
want restore deleted videos off jazzdv
  • Cameras
