20 Most Recent Frigidaire FRT21H8 Top Freezer Refrigerator Questions & Answers
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Frigidaire... | Answered on Aug 10, 2019
sounds like a weak compressor or low on gas be ready to buy another one,your one is dying
Frigidaire... | Answered on Mar 06, 2018
Hello
It is caused by a clogged defrost drain in the freezer compartment of your refrigerator
To fix this you will need to empty your refrigerator and unplug it.
Remove the back panel of the freezer and look under the cooling coil, you will see a frozen drain
pour hot water on the drain hole until water flows freely through the drain to the bottom pan..
That's it
Frigidaire... | Answered on Jun 04, 2015
you should be able to reverse your doors just take bolts out on hinges pop out plugs on oppasite side
Frigidaire... | Answered on Oct 06, 2014
We have summarised all possible problem for this case here to this link
http://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
Frigidaire... | Answered on Mar 02, 2014
Here's the manual you need with the parts lists. http://www.hammerwall.com/Download_Manual/37232/ On the first page, it has "parts" numbers for the other manuals you may need that I'm sure you could also find online with a Google search.
Here is the website that carries the part: http://www.needapplianceparts.com/218673008.aspx You might be able to find the parts elsewhere online.
Frigidaire... | Answered on Jan 22, 2014
Good Afternoon frnk, thank you for allowing me to assist you!
Your new high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become common to you. This also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable. If the noise, however, become louder or more pronounced, then you may want to connect with a local appliance technician to determine if anything else may be the cause.
Frigidaire... | Answered on Oct 17, 2013
Hello Georgia Peterson - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means that the unit has a faulty compressor or a sealed system leak. Also there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Frigidaire... | Answered on Jan 15, 2013
Im not familure with this item but on the older style fridge ice would build up in the freezer blocking the air ways to the bottom half of the fridge in this case you would need to remove the food from the freezer and fridge and unplug it open the doors and let it thaw out for a day or so I wish you luck and I hope this was helpful
Frigidaire... | Answered on Dec 07, 2012
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
Frigidaire... | Answered on Dec 04, 2012
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
173 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frt18drh fridg every time comes
  • Refrigerators
