20 Most Recent Kodak EASYSHARE Z1285 Digital Camera Questions & Answers
because of damaged gear.
Kodak EASYSHARE... | Answered on Oct 07, 2015
my first guess WB setting
pls change the White Balance setting to normal and check if you have the problem rectified
cheers
pls rate if it was any help
Kodak EASYSHARE... | Answered on Aug 24, 2014
dropped or banged it and broke the LCD and speaker by the description of the fault.
Kodak EASYSHARE... | Answered on May 25, 2014
If your camera is not dead, It is surely dying. Perhaps just a flat cable lost connection inside your camera, But more likely the electronics is on the end of life. My DX7590, started to act strange a few year ago, but I managed to shoot pictures still. I could not look back what I had shot, but I still made lots of pictures, till also shooting was impossible. (I could get the pictures from the memory card with an external card reader on my computer. My next step was again (a better) compact, but since over 2 years now I'm using a DSLR. I have learned a lot about digital photography with my Kanon camera's.
Kodak EASYSHARE... | Answered on Jan 23, 2014
Why not try ebay?
I found different rechargeable with and without chargers here. 2CR5 Rechargeable eBay
Kodak EASYSHARE... | Answered on Jan 21, 2014
Time to have it checked by camera tech, no user fix.
Kodak EASYSHARE... | Answered on Jan 25, 2013
camera drive motor assembly going bad, very common for these model Kodak cameras, Buyer Beware, Made in China, Very low quality and not dependable !!
Kodak EASYSHARE... | Answered on Jan 24, 2013
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Kodak EASYSHARE... | Answered on Aug 07, 2012
Kodak EASYSHARE Z1285 Digital Camera Logo
145 questions posted
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
screen went black except narrow band
  • Cameras
