20 Most Recent Panasonic Viera TX-32LX70 32 in. LCD TV Questions & Answers
menu> setup> eco settings> no opperation off.
Panasonic Viera... | Answered on May 17, 2019
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Panasonic Viera... | Answered on Jan 28, 2019
the easy way is just google your tv how to do this set up is found on you tube you google search your tv then free view re-tune on you tube then scroll down to it.
Panasonic Viera... | Answered on Nov 16, 2018
Well first I trust you removed the USB stick!
I would say that some software clash occured and the best way I know would be to try and get to setup or initial set up and then use factory reset to restore its software to default.
Should this fail then as a new set refer back to the seller for help as they have a duty to it for repair.
As for that memory stick was it blank or have pictures on it? has it got a virus? or other software that may clash.
In my view it should be formatted by the tv if it is for recordings or just carry images that your tv can support like say .jpg files other software programs could be a problem for it.
Hope this helps........
Panasonic Viera... | Answered on Jul 02, 2017
Hi Geric1,
Reset your unit to factory settings. Follow this instructions :
1. On your remote control press the "menu" key.
2. Press the "right" key >.
3. Select "set-up" by pressing the "down" (v) key. Then press "OK" key.
4. Select "shipping condition" by pressing the "down" (v) key. Then press "OK" key.
After this go to menu again then select the set-up but this time access the tuning menu and then auto set-up to set all channels available in your area.
Your done, Exit to. Checked if the unit restore factory settings.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Panasonic Viera... | Answered on Nov 02, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Panasonic Viera... | Answered on Oct 07, 2016
HDMI is a signal what do you have going on here?
Panasonic Viera... | Answered on Oct 04, 2016
Panasonic Viera... | Answered on Aug 26, 2016
When you plug in to the aux audio jack, that cuts out the speakers automatically. There is no switch.
Panasonic Viera... | Answered on Jan 22, 2016
CALL YOUR CABLE PROVIDER THEY WILL GUIDE YOU MR. ROBERTS
Panasonic Viera... | Answered on Jan 21, 2016
MYGOODFELLOW, YOU HAVE TO SWITCH FROM TV TO AV 1
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Panasonic Viera... | Answered on Jan 08, 2016
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Panasonic Viera... | Answered on Nov 14, 2015
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Panasonic Viera... | Answered on Oct 17, 2015
If you have another TV fed from the same antenna, I assume you have a splitter/distribution amplifier because you know you cannot just join two cables together don't you?
It is more than likely the splitter/amplifier, cable or connections rather than the TV but to make sure you must move the TV in the other room and try it on the suspect cable before condemning the TV.
Signal problems are usually due to water ingress and this could have happened on just one cable.
Failing that, the TV input could have failed. It is not common but does happen now and then.
Panasonic Viera... | Answered on Jun 04, 2015
This has to do with the network & not your TV. For various reasons the networks may vary the overall time of programming, therefore you should schedule your recordings extending the record time.
Panasonic Viera... | Answered on May 16, 2015
Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
296 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VIERA Panasonic
  • VIERA Panasonic
Most Popular Question
signal strength excellent but quality up
  • Televison & Video
