20 Most Recent ASUS Eee 4G Notebook Questions & Answers
In order to use the fixya expert utility, you need to have 30 free solutions posted within the last 30 days :c)
ASUS Eee 4G... | Answered on Aug 19, 2019
Notebooks are not the best computers for gaming, but if you have nothing else you can:
~make sure all programs are closed (including background programs)
~set the game settings to lowest quality
~if you have an external monitor unplug it and use just the notebook screen
~upgrade you RAM
ASUS Eee 4G... | Answered on Jul 12, 2019
Do what the other one above suggested if that does not help go to device manager uninstall the driver then restart computer that should fix the issue if still does not work this go back to device manager and uninstall the driver and then manually install the driver you downloaded from the website(make sure its the correct driver)
Should be good to go have a good day!
ASUS Eee 4G... | Answered on Sep 14, 2017
Go to control panel and disable/re-enable the mouse
ASUS Eee 4G... | Answered on Sep 02, 2017
OS is corrupted and needs to be reloaded.
ASUS Eee 4G... | Answered on Apr 23, 2017
It could just be that the electronics in the wireless adapter has failed. Do bother with getting it repaired, much cheaper to replace it with a USB version.
http://www.bestbuy.com/site/asus-dual-band-wireless-ac-usb-network-adapter-black/5732405.p?skuId=5732405
ASUS Eee 4G... | Answered on Mar 16, 2017
victoria_999 --
Press Fn + F2
"Fn" stands for "function", is located at the bottom-left portion of your keyboard.
If you notice, the color of the wifi icon is different than the letter keys... the color should match the Fn button
This will turn on/off your wireless adapter :)
Hope this helps!
-- RT
PS - Please don't forget to vote!
ASUS Eee 4G... | Answered on Nov 05, 2016
My dear friend:
Linux OS is like having a mac system, and wifi don't work well with linux , but on other hand, if you were using the airmax by apple, you will not have a problem.
microsoft vista will be the right choice for your Asus notebook, change your OS, and using your wifi will be NO problem any more.
enjoy!
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
ASUS Eee 4G... | Answered on Oct 27, 2016
SHIFT and the number 2
ASUS Eee 4G... | Answered on Sep 27, 2016
reinstall service pack 3 with language pack from microsoft.Make sure you back up your registry first.
For xample
If you have XP SP2 in ENG and want to have it iArabic, you will have toDownload SP3 in Arabic (http://www.Microsoft.Com/downloads/details.Aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en change language to desired one then download), change some registry Keys (go to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Nls\Language Registry Key, and then change the value date for “Default” and“InstallLanguage” Registry value from 0001to 4001) reboot and you'll be able toInstall SP3 in Italian.
  • 0001 = "ar;Arabic"
  • 0401 = "ar-sa;Arabic (Saudi Arabia)"
  • 0801 = "ar-iq;Arabic (Iraq)"
  • 0C01 = "ar-eg;Arabic (Egypt)"
  • 1001 = "ar-ly;Arabic (Libya)"
  • 1401 = "ar-dz;Arabic (Algeria)"
  • 1801 = "ar-ma;Arabic (Morocco)"
  • 1C01 = "ar-tn;Arabic (Tunisia)"
  • 2001 = "ar-om;Arabic (Oman)"
  • 2401 = "ar-ye;Arabic (Yemen)"
  • 2801 = "ar-sy;Arabic (Syria)"
  • 2C01 = "ar-jo;Arabic (Jordan)"
  • 3001 = "ar-lb;Arabic (Lebanon)"
  • 3401 = "ar-kw;Arabic (Kuwait)"
  • 3801 = "ar-ae;Arabic (you.A.E.)"
  • 3C01 = "ar-bh;Arabic (Bahrain)"
  • 4001 = "ar-qa;Arabic (Qatar)"
If noProblems occur, you will have the whole system language changed.
ASUS Eee 4G... | Answered on Jul 29, 2016
if it is PDF format, scroll down the pages until you find the pages you want
the page number will be in the column on the RH side of the screen or in the number box at the top (20/64 etc)
go to the printer on the PDF page and when the print section opens up , change the print all- to pages and enter the page numbers you want
each page number separated by a comma --example 20,21,22,23,24 then press print and only those pages you nominate will print out
ASUS Eee 4G... | Answered on May 15, 2016
I would do a google search for the questions. You have to make the usb bootable and there are several ways to do it.
ASUS Eee 4G... | Answered on Mar 05, 2016
Apple is bad for this. Somehow there is a link to reset your password.
http://www.unlockbiosrecovery.com/Unlock_ASUS_Bios.php can calculate a bios master password for your ASUS notebook for $20 and they guarantee it to work. The bios master password will clear the currently set bios password, giving you full access to bios setup. I repair laptops and I use them when I get a laptop with an unknown bios password or unknown hard drive password and they have always worked for me.
ASUS Eee 4G... | Answered on Jan 31, 2016
Hi this is Alex Walker expert to help you for this Issue Call +1(404)981-1535 I will be glad to assist you
ASUS Eee 4G... | Answered on Dec 28, 2015
  1. Open Regional and Language Options by clicking the Start button , clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
ASUS Eee 4G... | Answered on Sep 16, 2015
You forgot to tell us what the Os do youuse.
Well, that's nothing. You can reference the methods to different systems below:
BreakWindows 7 password
CrackWindows Xp Password
HackWindows Vista Administrator Windows Password
ASUS Eee 4G... | Answered on Sep 06, 2015
1,537 questions posted
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
administrator password reset
  • Computers & Internet
