20 Most Recent Dometic NDR 1062 Refrigerator Questions & Answers
that is a fusible link in bend metal holding it pull out and change make sure if using LP burners clean and good pressure if electric check stack for clog or if vent fans that they are working unit overheated
Dometic NDR 1062... | Answered on Dec 23, 2017
possible selector switch try unplugging to see if works
Dometic NDR 1062... | Answered on Sep 27, 2017
shorted board or heater element
Dometic NDR 1062... | Answered on Jun 18, 2016
check all gfci resets and if plugged in check convertor voltage if below 10 volts will not run fridge panel runs off of 12 volts check fuses in front by tongue jack
Dometic NDR 1062... | Answered on May 30, 2016
bad switch replace
Dometic NDR 1062... | Answered on May 27, 2016
move temp sensor off of coil let hang if same replace temp sensor
control unit runs off 12 volts 120 volts for heater element
should
Dometic NDR 1062... | Answered on May 25, 2016
that is a fusible link it is a series circuit
I finally did a Google search for the NDR 1062 and found the Illustrated parts breakdown on PPLs web site. Also, received an email from a helpful reader of Fix-Ya Site with another site that had the parts manual.
Dometic NDR 1062... | Answered on Jan 03, 2015
Not unless you unplug the thermistor from the circuit board and let it run for 24 hours. If it does not cool after that then your cooling unit is bad.
Dometic NDR 1062... | Answered on Jul 02, 2014
Your cooling unit has leaked, the green fluid you see is the ammonia solution. We are Arcticold Refrigeration. Our NEW replacemnt cooling units come standard with new installation hardware, installation instructions, and a lifetime warranty. Our products are a cost effective solution to buying a new fridge and our units outperform the factory installed units. Our Units are "Built tough to last a Lifetime"Give us a call 1888-782-6665 ArctiCold Refrigeration We keep it cold I have attached a pic bellow of an Arcticold built NDR1062 cooling unit. c9cd0543-0253-4ec8-b002-2cece05f86e6.jpg 3e135613-2b82-4462-bd42-72e04ed7e14f.jpg
Dometic NDR 1062... | Answered on Mar 07, 2014
Dometic NDR 1062 Refrigerator Logo
69 questions posted
Top Dometic Refrigerators Experts
Sheldon Dedek
John Tripp
John Tripp
Paul G
Paul G
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Refrigerators
Most Popular Question
not cool either ac or gas green fluid
  • Refrigerators
