20 Most Recent Memorex M-Flyer 1GB USB 2.0 TravelDrive Questions & Answers
Hi if the stick is corrupted and you have no files currently on it have you tried reformating it. that may remove the corruption
Memorex M-Flyer... | Answered on Mar 23, 2017
you can send it off to one of those companies that specialise in data recovery if not all you can do is reformat :(
That is why they are secure ..... sorry :(
Memorex M-Flyer... | Answered on Jan 17, 2015
As it turns out, something on your USB drive has been corrupted. It is impossible to access the files already there, but if you want to use it in the future you will have to click "yes" when the computer prompts you to format it.
Memorex M-Flyer... | Answered on Jun 17, 2011
your pendrive is damaged. pendrives are hardly repairable, i am afraid you will to buy a new one. however you can try connecting it to different pcs with different operating systems and processors. if it still doesnot work on any of them, you can replace it with a new one.
Memorex M-Flyer... | Answered on Feb 04, 2011
hi
u have virus in HDD run that with antivirus will detact viruses and i will repairs
Memorex M-Flyer... | Answered on May 15, 2010
Well answering first part of your problem is quite lengthy. In short its a virus. In order to retrieve your pen with its original capacity you are required to take your pen to a linux machine. since the virus on your pen is exe and no exe runs on linux without wine software. hence, if you format your pen on linux machine though mkfs2 command your pen will be cleaned. but the virus will remain there on your windows machine.
Memorex M-Flyer... | Answered on Apr 10, 2010
First you must create a password protected section.
Memorex M-Flyer... | Answered on Feb 05, 2010
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Memorex M-Flyer... | Answered on Jan 30, 2009
let me suggest i ur able the flash drive icon when you go in desktop or my computer then right click on that drive and click the option format and follow instructions, if you are able to format successfully, then no worries if formatting is not done.....
ii) then try to keep your windows'xp or vista cd in the cd tray and restrat system and follow the procedure: formating system(dont wory im  nott going to install or reloading OS ), when u reach a position where u see all the partition(like c, d ,e drive ... with memories), u will also see the flash drive partition along with hard-disk partion separately...
now click on the flash drive partition and press the button D to delete partition and follow instruction after do this , press C to create partition and u will see that a letter(e, f..) will be given to our flash drive....
now quit xp (by pressing ESC, donot proceed loading XP or vista) and now restart system and i think ur flash drive will work.....
Memorex M-Flyer... | Answered on Dec 31, 2008
Stomp is computer backup software.
Memorex M-Flyer... | Answered on Nov 26, 2008
Ok plug the the device into your usb port. Most usb devices have lights letting you know they are working. After plugging it in if your using Windows goto "My Computer" and look for a new Drive letter like when I plug mine in it says NO_NAME(G:) and then I can access the flashdrive just likes its a regular harddrive. Now you can always already have "My Computer" open so you can see the new drive letter pop up. Don't look for (G:) yours can be different but it might also be named something like TravelDrive(F:) thats just an example. I hope this helps you
Memorex M-Flyer... | Answered on May 01, 2008
Try using another program. MiniTool Partition Wizard works very well.
Memorex... | Answered on Aug 17, 2014
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.htm
Memorex... | Answered on Dec 20, 2013
It needs to be aligned at a video shop.
Memorex... | Answered on Jun 28, 2012
Easiest thing is to re-format it from Properties
Memorex... | Answered on Apr 25, 2010
Memorex M-Flyer 1GB USB 2.0 TravelDrive Logo
Popular Tags
17 questions posted
Top Memorex Electronics - Others Experts
David Ellis Rhea
JonSnell Electronic
JonSnell Electronic
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Memorex Electronics - Others
Most Popular Question
get memorex usb 2 0 traveldrive
  • Electronics - Others
