20 Most Recent Sony Bravia L-Series KDL-32L5000 32-Inch 720p LCD HDTV, Blac Questions & Answers
Use code search on your URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Sony Bravia... | Answered on Mar 01, 2019
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sony Bravia... | Answered on Sep 09, 2014
Main board problems
Sony Bravia... | Answered on Dec 19, 2013
First check it by connecting a DVD player or games console to it to see if the picture behaves with them feeding it. I will assume they also fail. When it fails try going up a channel and see what happens then. So If the backlight (which is a few simple flourescent tubes) also went off AND the sound went off I would say there is a fault in the power supply, inside the TV, but the sound stayed on so this is a very unusual fault. I think it may be switching to a mode of operation where the picture is deliberately suppressed. A factory reset should have cleared this so there is an electronic problem, for most TVs its not cost cost effective to repair any of the internals.
Do you think you can do it right? If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Sony Bravia... | Answered on Oct 23, 2013
First of all, please ensure that the power outlet is ok. During such power surges, normally the power outlet gets affected. Try the TV on a different power outlet. The relay clicking on/off could be due to some components short in the primary supply.
Sony Bravia... | Answered on Aug 28, 2012
Hi Sherry, you can test your remote control to see if all the keys work correctly
Take your cell phone, put in camera mode and point the emitting LED of the remote control towards the camera,
press the keys, one at a time and see if the emitting LED is illuminated, if so, try the volume up key, if the light does not turn on, you could carefully disassemble the remote control and clean the contacts and the keyboard internally rubber,
Do not use alcohol to clean
the rubber keyboard, you can clean it with warm water and detergent then let it dry very well,
the contact plate, you can use a cloth with some liquid to clean the glass,
the idea is to remove the rubber residue on the contacts
then arm again and test, but you have results consult a specialized technical service
I hope you find the suggestion useful
Greetings Franco Dosil
Hola Sherry, puedes probar tu control remoto para saber si todas la teclas funcionan correctamente
Toma tu celular, pon en modo camara y apunta el Led emisor del control remoto hacia la camara,
presiona las teclas, una por vez y fijate si se ilumina el Led emisor, si es asi, prueba la tecla de subir el volumen, si no se prende la luz, podrias desarmar con cuidado el control remoto y limpiar internamente los contacto y el teclado de goma,
No Uses Alcohol para limpiar
el teclado de goma, lo puedes limpiar con agua tibia y detergente luego dejalo secar muy bien,
la placa de los contactos, puedes usar un pa?o con un poco de liquido para limpiar los vidrios,
la idea es sacar el residuo de goma que hay sobre los contactos
luego arma nuevamente y prueba, sino tienes resultados consulta a un servicio tecnico especializado
Espero te resulte util la sugerencia
Saludos Franco Dosil
Sony BRAVIA... | Answered on Sep 15, 2019
hello Dear
this is panel problem please replace panel
Thanks
M Nasir
Sony BRAVIA... | Answered on Apr 14, 2019
Aron,
To perform a reset you will need to disconnect the TV completely from power for at least 30 seconds, if this doesn't resolve your problem then you may have hardware that has expired in your device. Without physically looking at your device I can't say with certainty what your problem is, it could be your PCB. There are video's online you can visit on how to test a PCB for faults.
If you are not comfortable troubleshooting your device I would suggest contacting a local electronic repair shop near you, however I will link you to a generic instructional video showing you how to perform basic troubleshooting of your device.
Hope this helps,
Best regards
https://www.youtube.com/watch?v=qxG3hmmvkJs Testing LCD TV Power Supply BoardsSTEP BY STEP
Sony BRAVIA... | Answered on Mar 08, 2019
Although I am just guessing, most Sony equipment uses metric screws. Go to a Home Depot or similar store and take the piece that you have that contains the threaded fittings and they will help you find the screws you need. https://www.manualslib.com/manual/793567/Sony-Kdl-32xbr6.html?page=7#manual This page of the manual gives some info about the screws such as not longer than 1/2" (or 12mm) to prevent damage to the set. Sony customer service may be able to supply replacement screws too.
Sony BRAVIA... | Answered on Feb 18, 2019
Go to the initial set up procedure and disable it.
Sony BRAVIA... | Answered on Feb 14, 2019
Open internal fuse or power supply failure
Sony BRAVIA... | Answered on Jan 23, 2019
Unplug from wall for 60 secounds then plug back in. See if that works.
Sony BRAVIA... | Answered on Jan 19, 2019
Press the HOME button on the remote control.
Select Settings.
Select System Settings.
Select Customer Support.
Select Factory Settings.
Select OK.
Sony BRAVIA... | Answered on Jan 18, 2019
THe antenna came of. Did you use it and is it giving troubles now? If not, then don't mind and leave it.
Sony BRAVIA... | Answered on Jan 17, 2019
Sony Bravia L-Series KDL-32L5000 32-Inch 720p LCD HDTV, Blac Logo
Popular Tags
10 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony model kdl 32l5000 dont remot need
  • Televison & Video
