20 Most Recent Sharp AQUOS Blu-ray Disc Player Questions & Answers
Make sure that the blu ray player is indicating that the latest firmware is installed on it. Press the setup button go to settings and down to version. Then record the version number. If it is the most current firmware version number after all call 800-237-4277 pressing 1 for all of the prompts. Inform the representative that with the firmware version number installed on your bluray player you are having this problem with Avatar. This helps because Sharp is
gathering information on any occurrences after an update and they are working on another update to resolve any occurrences
Sharp AQUOS... | Answered on Aug 09, 2019
from sharp. It says in your operation manual that you need to call 1800 Be Sharp to get the stuff to update. Its something that you have to purchase
Sharp AQUOS... | Answered on Aug 07, 2019
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
hi..ya you can play jpeg through the blue-ray
player.
check it out..
thank u..
rate me..
Sharp AQUOS... | Answered on Aug 06, 2019
If all other discs play, and only blu-rays cannot, the fault must be of its laser pickup unit.
contact HP drivers support number to fix the error codes to fix the issues in HP printer
http://www.hptechsupportphonenumber.com/download-install-hp-printer-drivers/
Sharp AQUOS... | Answered on Oct 03, 2018
Firmware is tricky and the manufacturer wont warranty any installation of it except by their factory techs. There are too many things that are out of their control. IF you could tell us what steps you took to install it, that might be helpful.
Sharp AQUOS... | Answered on Dec 05, 2017
Go to the manufacturers product support website of the Blueray player and check for updated firmware releases.
Sharp AQUOS... | Answered on Jul 13, 2017
Look for a firmware upgrade for your player. They exist for sole purpose of increasing compatibility with newer blu ray releases. If that does not do the trick it appears that your player's laser assembly is losing its ability to focus on the disk(s). Repair is not cost effective and you will have to go shopping.
Sharp AQUOS... | Answered on Mar 31, 2017
Logitec make a nice remote but check to make sure it works with your player. Some are limited to units made in last 5 years or so. Older units may not. I know it does go back quit a ways for all remotes.
Sharp AQUOS... | Answered on Jan 29, 2015
Its highly likely a cable issue. You know which cable connection is wrong if are using component in and out. But change to a new connection cable whatever it is and I think it will be solved
Sharp AQUOS... | Answered on Mar 08, 2014
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Sharp AQUOS... | Answered on Mar 07, 2014
Sharp AQUOS Blu-ray Disc Player Logo
274 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
way hook ethernet sharp br model bd
  • Televison & Video
