20 Most Recent Samsung S860 Digital Camera Questions & Answers
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory card to the computer via either the camera or preferably with a usb card reader , run the program.
On the program , select the dig deep option for accidentaly deleted files or dig deeper for a formatted card. Then select the card you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the pictures were lost. Save the files to a location on the computer hard drive and not back to the memory card as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
Samsung S860... | Answered on May 27, 2019
uFlysoft Photo Recovery for Windows is an advanced utility that recovers lost images, audios, video clips, and pictures from almost all digital cameras, memory cards, hard drives, memory sticks, USB flash drives, and various others. The easy-to-use Photo Recovery utility is available for both Windows (Windows 7, Vista, XP, 2003, 2000, and 2000) and Mac (Mac OS X 10.6 (Snow Leopard), 10.5 (Leopard), 10.4 (Tiger), and 10.3.9 (Panther)Use the Data Recovery for Mac to acheive Photo recovery on Mac) operating systems.
Samsung S860... | Answered on May 15, 2019
Bypass Lock Screen on Samsung Galaxy without Data Loss
Android Lock Screen Removal & Data Recovery is a famous tool for removing password on Android lock screen without data loss. With the help of this program, you could bypass pattern/password on Samsung Galaxy lock screen without losing data.
Android Lock Screen Removal supports to remove 4 lock screen types on Android - pattern, PIN, password & fingerprints. Simple and easy to use. Android Lock Screen Removal works for Samsung Galaxy S/Note/Tab series, including Samsung Galaxy S9/S8/S7, Samsung Galaxy S6.
LEARN MORE
Broken Android Data Extraction
How to Unlock HUAWEI Phone with Broken Screen
http://datas-recovery.com/static/Restore-photos-from-black-screen-Nokia.html
How to Restore Contacts from Black Screen Nokia
http://datas-recovery.com/static/Restore-sms-from-black-screen-Nokia.html
Samsung S860... | Answered on Mar 12, 2019
Go to the following site and download the manual.
http://www.samsung.com/us/support/downloads/SAMSUNG%20S860
The manual explains everything you want to know.
Samsung S860... | Answered on Mar 11, 2019
Any samsung smart-phone cable will do the trick. Or you can put your SD Card directly into a computer
Samsung S860... | Answered on Jun 23, 2015
Yes, low-light photography is difficult, precisely because there isn't much light. In order for the sensor (or film, for that matter) to record what little light there is, the shutter has to stay open longer. This gives the subject more opportunity to move, resulting in blurring. Worse, this gives the camera more opportunity to move, resulting in more blurring. The situation is much worse in a compact camera such as the S860, which has a much smaller sensor than a dSLR. In order to pack as many pixels into a smaller sensor, each sensor is less sensitive to light.
If the subjects are not too far away, and at more or less the same distance, you can use flash, either on the camera or off. If the subjects are too far away, the flash won't make any difference. If the subjects are at differing distances, nearer ones will be much brighter than the farther ones.
You can raise the ISO to make the sensor more sensitive to light. This also increases digital noise. How much noise is acceptable is your call. You'll have to take the S860 out of Auto mode for this, though, and the results will still not be as good as you'd get out of a dSLR.
The best way to stabilize a camera is to use a tripod. Failing that, you can use a table, railing, window sill, or other steady surface, in conjuction with the self-timer. By using the self-timer, you give the camera an opportunity to quit moving after you pull your hand away.
None of these suggestions will make low-light photography easy, merely less difficult. Entire books have been written on the subject of available-light photography, your local public library may have one or two.
Samsung S860... | Answered on Jan 28, 2015
No. The S860 uses standard AA batteries. If you want to use rechageables then you must charge them outside the camera using a separate charger.
Samsung S860... | Answered on Oct 04, 2014
Kindly check the battery and The Battery Is Properly Fitted And Charge
Samsung S860... | Answered on Jun 12, 2014
Just switching off and on is not enough. You could try one step further. After switching off, remove the battery and memory card for a little while just a few seconds should be enough.
To make sure the memory card is still working, put it in an external memory card reader and look on the computer you still have pictures on it. If the card gives an error in the computer, try recover software, to retrieve your pictures. If the card looks ok, replace the memory card and the battery and switch on again.
But also make sure the battery is charged.
If after this still the same error occurs you should visit a repair centre, or start saving for a new camera.
Samsung S860... | Answered on Jun 10, 2014
None of the suggested solutions worked for me and my Elph 300HS. However, I took it apart, removing the back. There was a screw inside holding on the front panel which I could not budge no matter what, so I gave up. I put it back together, reinserted the battery, powered on and voila, it was back to normal. Perhaps disconnecting the battery for a while was key. Had I not tried the multi-step approach suggested, it would still be stuck. Caution: Beware the capacitor. It must be discharged if you go into the camera or it can knock you across the room.
Samsung S860... | Answered on Jan 13, 2014
449 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
while setting up display features start
  • Cameras
