20 Most Recent Olympus FE-340 Digital Camera Questions & Answers
Sounds like a fault with the lens mechanism, would need to be serviced by Olympus but will most likely cost more than camera is worth
Olympus FE-340... | Answered on Apr 03, 2016
If the pictures have lines or marks in them when loaded up on a computer screen then it's a fault with the image sensor inside the camera, if they do not then it's a fault with the lcd screen on the camera, either way it's not an easy fix and will probably cost more than a new camera
ur memory card is write protected...theres this lil switch on the memorycard jus flip it the other way n ur good as new
This FE-340 Olympus is a great camera. Lots of features and usually great results
  • Indoor pictures with flash set on auto WB (white balance) should not be a problem
  • Indoor pictures without flash requires setting the WB to match the light source in the room (incandescent, florescent etc) Outdoor pictures WB on auto generally not a problem
For more help Include a photo with the metadata of the photo from the image data file
Olympus FE-340... | Answered on Dec 02, 2015
Have you replace the batteries? with a good lithium battery.
Olympus FE-340... | Answered on Feb 14, 2015
Maybe your auto focus is turned off, and your relying on it to focus for you..
Olympus FE-340... | Answered on Oct 03, 2014
Your lens is dirty or when you take the picture the exposure setting is took long and then any movement will make the picture look blurry.
Have you tried putting the camera on a table and taking a picture?
Olympus FE-340... | Answered on Aug 27, 2014
One thing to try is take battery out, clean the contacts and check battery compartment and make sure the is inserted back in correctly. Inspect the USB port, it may have the pins touching each other. The USB will deactivate the screen when you connect to computer or TV. Inspect the screen for cracks or discoloration, you will need to replace the lcd screen if you notice this.
Olympus FE-340... | Answered on Jun 19, 2014
Did you try to press the display button several times? Most of the time you can cycle through different views on the display, with different information during record mode. One is display off.
Olympus FE-340... | Answered on Jun 18, 2014
Olympus FE-340 Digital Camera Logo
289 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
failed transfer images
  • Cameras
