20 Most Recent Miele Professional PT7136 Little Giant Stainless Steel Laundry Dryer Stackable, 15Lb 6.5Kg 34Gal 4.6CF Honeycomb Drum, Hot/Cool Air, Moisture Control Questions & Answers
i don't know. first guess is regular drying cycle makes predetermined heat levels and sensor that shuts off heat and dryer when it decides clothes are dry. 20/40 minute
choices may be fan only unless there is a manual temperature control that you can set eg. off/low/med/high..
Miele Dryers | Answered on Aug 30, 2019
it could be the thermostat is getting to hot. check to make sure your vent is not clogged causing to over heat thus tripping the breaker. also if you are versed enough to take machine apart to look at the blower motor sometimes known as a squirral cage, material can build up in that causing it not to spin thus tripping a breaker
Miele Dryers | Answered on Aug 18, 2019
The drum is overloaded (too much laundry), or there is a problem with the moisture sensor not registering the moisture content of the laundry correctly.
Miele Dryers | Answered on Jul 11, 2019
This is a pretty complex task - but
Remove top lid
remove control panel
remove front panel and door
remove the right side panel
remove the front support panel ( supports the drum)
the impeller will now be seen lower right of machine
Hold motor pulley while loosening impeller nut
Replace impeller
Miele Dryers | Answered on Mar 03, 2019
Most likely the Brushes on the Moisture sensor need to be replaced - it should work on timed dry as this function doesn't use the brushes
I DON'T KNOW. MOST DRYERS HAVE 4 WIRES, TWO
CARRY ELECTRICITY. SHUT OFF DRYER OPEN DOOR.
CHECK THE HOUSE ELECTRICAL PANEL SEE IF TWO
CIRCUT BREAKERS NEED TO BE RESET. THEY ARE
USUALLY CONNECTED TO EACH OTHER. SWITCH
BACK AND FORTH, THEN TO ON.
IF YOUR HOME USES SCREW IN FUSES, TAKE THEM OUT AND TEST THEM WITH A METER. OR PUT IN NEW ONES. SHUT DRYER DOOR. TURN ON DRYER.
IF DRYER HAS PLUG FAULT THERE, I DON'T KNOW.
BE EXTRA SAFE WHEN WORKING NEAR ELECTRICTY.
SOMEONE WITH KNOWLEDGE AND A SUITABLE
METER COULD CHECK YOUR LARGE 4 WIRE WALL
RECEPTICAL FOR YOUR DRYER.
{LOOKING BACK, IT IS WHAT I SHOULD HAVE DONE.
OUR DRYER WAS RUN FROM A SMALL 7 X 10 INCH
ELECTRICAL BOX WITH 30 AMP SCREW IN FUSES
AND NOT DIRECTLY FROM THE LARGE MAIN PANEL.
ALL SEEMED OK. CALLED LOCAL REPAIR MAN. NO CHARGE BY PHONE - BLESS HIS HEART. ""CHANGE THE DRYER SMALL ELECRICAL FUSE BOX"". THE
BOX I CHECKED AND FOUND IT WAS OK. ANYWAY,
I DID - SURE ENOUGH THAT WAS MY PROBLEM SOLVED.]
Miele Dryers | Answered on Feb 10, 2019
Miele Professional PT7136 Little Giant Stainless Steel Laundry Dryer Stackable, 15Lb 6.5Kg 34Gal 4.6CF Honeycomb Drum, Hot/Cool Air, Moisture Control Logo
3 questions posted
Top Miele Dryers Experts
Mike
Dw Wooten
Dw Wooten
ray gallant
ray gallant
Are you a Miele Dryer Expert? Answer questions, earn points and help others
View Most Popular
Miele Dryers
  • Miele Dryers
Most Popular Question
tumble dryer type pt7136 tumble
  • Dryers
