20 Most Recent D-Link (DIR-130) Router Questions & Answers
Yes, you can reset the password of your D-Link router. follow this steps:
  • Type 192.168.0.1 in the address bar of your Computer Or Phone & Press Enter
  • Now if you like please change the Network Name (SSID) & Password & Hit Next Please Choose a Complex Password Including Numbers & One Cap & All Letters ( Recommended )
If you have any problems visit here: https://wirelessrouterexpert.com/router/setup-configure-dlink-router
D-Link (DIR-130)... | Answered on Aug 28, 2018
try going to the website where quick setup or what-ever-you-call-it is
D-Link (DIR-130)... | Answered on May 10, 2014
if you know your model number (should be on the router) the link attached will show you exactly how to do it on the router How to forward ports on Netgear routers
D-Link (DIR-130)... | Answered on Jan 14, 2014
Use the hardware reset button. Using this button will reset it to manufacture's default settings. Setting username: admin password: blank
D-Link (DIR-130)... | Answered on Aug 23, 2011
To change you password, launch your configuration screen (by typing in 192.168.0.1 in the address bar of your Internet browser), Login using default username and password as above, and then click on "Run Wizard." You will have an option to Set your new password, Set your time zone, and to Set Internet connection. Follow the screen prompts, and restart your DLINK router/modem when done.
If you are having trouble resetting your password, double check your product documentation to find out how your product has been preconfigured prior to shipping. If you still cannot log in, double-check your password (if any), and make sure that your CAPSLOCK key is off. If all else fails, use that little "reset" button at the back of your D-Link router/modem and hold it down for 10 to 30 seconds (depends on your unit) to restore your networking hardware to factory default settings; and start over.
Hope this helps.
Thanks for choosing Fixya,
RJ
D-Link (DIR-130)... | Answered on May 15, 2011
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
D-Link (DIR-130)... | Answered on Jan 23, 2011
Ob these stuff there should be a reset button on the back, or the bottom. The type that you simply can't see, and to push it, you need a pen, pencil, whatever.
If you got the reset button, then it takes every preferences back to default.The default password on D-Link routers is "admin" (without ""s).
D-Link (DIR-130)... | Answered on Dec 29, 2010
try using different PC or laptop or move to different location dependign on the streght of the signal and also make sure that dlink is properly connected. or unstall anr re-instal your Dlink if it does not work your dlink may be defective.
D-Link (DIR-130)... | Answered on Oct 08, 2010
You can reset yout router provided that u have ur ISP/Internet account password known.
To reset dlink router,
1. Switch ON the router
2. you will see small reset switch in back.
3. Press and hold the reset switch for 30sec while the router is powered on.
4. Then leave reset switch, unplug powercable.
5. Then after 10secs, Switch ON the router.
6. Its done. goto router homepage as usual.. then proceed to setup internet settings.
VOTE for me.,
D-Link (DIR-130)... | Answered on Sep 24, 2010
Reset the router.
Push something small in the reset hole on the back, some routers need to be switched off, then push the reset and keep it pushed for about 20 seconds after you have switched it back on
D-Link (DIR-130)... | Answered on Jul 26, 2010
Buy 2 DIR 130 VPN routers and connect the two office networks via LAN-LAN VPN tunnels.
If you have the time and skills you can build two IPCOP firewall routers and connect via VPN tunnels (http://sourceforge.net/apps/trac/ipcop/wiki)
D-Link (DIR-130)... | Answered on Apr 07, 2010
You can reset the D-Link router to the factory default by :-
Powering up the router and pressing the reset button at the back of the router nest to the power socket.
open your browser and in the URL address box type in :-
http://192.168.0.1
The default login is admin and the password is left blank.
D-Link (DIR-130)... | Answered on Sep 20, 2009
you need a router to make that possible using wired or wireless connection.i hope this helps
D-Link (DIR-130)... | Answered on Sep 15, 2009
Most routers do a complete reset if you hold in the reset button for 30 seconds including the password.
D-Link (DIR-130)... | Answered on Jun 08, 2009
There is a little hole beside the Power Plug.
This is the reset button.
You´ll need a little paper clip to press the button more then 3 seconds.
Then all in the box is resetet.
D-Link (DIR-130)... | Answered on May 02, 2009
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
D-Link (DIR-130)... | Answered on Mar 09, 2009
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
D-Link (DIR-130)... | Answered on Jan 11, 2009
You can get best d-link router support phone number at Toll Free Number ( 1-877-769-0969 ). D-link router Tech Support number ( 1-877-769-0969 )
D-Link Computers... | Answered 3 hours ago
D-Link (DIR-130) Router Logo
26 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
d link dir 130 in process saving
  • Computers & Internet
