20 Most Recent Canon Pixma MG3150 All-In-One Color Printer Questions & Answers
While not quire familiar with this printer I have some ideas.
first most paper detection involve either mechanical switches or sensors. The sensors use the white paper either to reflect or block the sensor beam. Then as paper moves through logic resets. ( from your message I think you know these but just put as refresher).
you have checked for physical paper and found none, so I would get a can of air and spray sensor slots as paper dust can build up over time and the dust looks like paper to the sensor. If you have air compressor open all cover and remove ink or toner and spray away.
this is more prevalent in the higher speed printers, but can build up over time.
Not sure if the printer says where the jam is located which would be helpful.
Canon Pixma... | Answered on Oct 09, 2016
The error code seems to indicate a problem with the print head. Below is a link to help you trouble shoot the issue
Canon PIXMA MG3150
Canon Pixma... | Answered on Aug 11, 2016
Are you sure the color ink hasn't dried out?
Pull the cartridge and carefully wipe the print head across a facial tissue or paper towel. Don't touch the metal contact points on the cartridge as sometimes the smallest static charge can destroy the cartridge.
Depending on the printer, setting it to color it may use only the color cartridge, but more likely it will use both the color and black to make up the print. Setting to black and white, not grayscale will force it to use only the black cartridge.
Here is an explanation, much like I suspected, and a cure.
(Fixya doesn't allow me to add a link at this point, so you'll have to drop this into your address bar.)
http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Canon Pixma... | Answered on Jul 21, 2016
If this isn't a driver issue I'd check to be sure the print head and ink cartridges are secure and not loose. Also check the drive belt on the head to be sure it's not slipping or broken.
Canon Pixma... | Answered on Apr 14, 2015
Lift feed panel, then the cover. carefully pull in thedirection of normal feed onto the scan plate. Do not try to pull out from the entrance.
Canon Pixma... | Answered on Mar 13, 2015
Did the camera come with a usb cord for connecting to external devices?
Canon Pixma... | Answered on Jan 25, 2015
You should have a disc that has all the drivers on to work the printer on your computer, if not go onto the Internet and type canon then make sure you select a Canon site not just one that offers canon info and along near the top should be a list of things to connect to chose driver updates, you can then choose your printer from a list then just download the drivers from there open and run them all should work then
Canon Pixma... | Answered on Dec 21, 2014
I think this problem is not related to your printer but rather the software you are trying to print from.
I think it could be printer related only if you see jagged lines, meaning you have to clean the printhead.
Please be more specific about what program do you use to open those music sheets and print from? What computer and operating system do you have?
Canon Pixma... | Answered on May 12, 2014
See this video John.
Canon Pixma... | Answered on May 10, 2014
Canon Pixma MG3150 All-In-One Color Printer Logo
98 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon mg 3150 bogus paper jam error e03
  • Office Equipment & Supplies
