20 Most Recent Mitsubishi WD-73736 Television Questions & Answers
There are some adjustments should be done after the DLP chip replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mitsubishi... | Answered on Jan 22, 2017
the model is amitsubihi MD-73736
Mitsubishi... | Answered on Jun 13, 2013
Remote sensor is always on front of set behind a clear or tinted small lens and inside it usually is on a circuit board .
Mitsubishi... | Answered on Dec 15, 2012
It means no signal found----double check entire hookup and of course make sure box on and connected to the correct input on the set.
Mitsubishi... | Answered on Aug 29, 2012
You need a 3D Blue ray player and 3D glasses. Make sure that the 3D feature is turned on on your Mitsubishi. You also have to have HDMI 1.4 cables. Anything lower will not produce 3D
Mitsubishi... | Answered on Apr 27, 2012
Bad capacitors on TV is usually found on power supply board..
it is connected next to power cord
Like this:
Mitsubishi... | Answered on Jan 06, 2012
HI:
The normal usage time for lamps are 6500 hours, thats a little under three years depending on the use of the television, These lamps last longer when they are not turned off and on all the time. The constant heating and cooling prematurely wears out the lamp, also on Mitsubishi lamps have a filter on their lamps that geta cloged with dust from the exaust fan, causing heat to become traped in the lamp compartment which will cause the lamp to blow premautrely, using a compressor try cleaning this filter every 6 months or so for longer llamp life.
Mitsubishi... | Answered on May 01, 2011
Mits has had an excessive number of problems with color wheels in some of their optical engines. Provided you replaced the lamp with OEM parts I would suspect the color wheel is causing the noise as well as the shutdown issues.
Bill W
integrityhomeworx.com
Mitsubishi... | Answered on Mar 14, 2011
Thats a mechanical adjustment called keystone. The service manual sjould outline that proceeduer for you. You can get the service manual by download link from www.servicemanuals.vstore.ca
Mitsubishi... | Answered on May 25, 2010
Have you tried the soft reset for this set? Menu, 1,2,3 enter? There is also a hard reset in the hidden Option menu you can try.
Let me know as much as you can.
SD TECH
Mitsubishi... | Answered on Mar 01, 2010
Click Vizio Support to download user manual of VW37LHDTY30A.
Hope this info will help you.
Thanks.
Mitsubishi... | Answered on Dec 01, 2009
Mitsubishi WD-73736 Television Logo
33 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
mitsubishi green power light keeps
  • Televison & Video
