20 Most Recent Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Questions & Answers
Hey I have the same problem on the one i just bought for 10 bucks, I was wondering if you could tell what the pink tube thing and the white tube things near the semiconductor that was screwed to the metal are? are they capacitors or what? please help.
Line 6 Spider... | Answered on May 15, 2016
While it could be true that you're having a problem with the guitar or cable as the previouse expert suggested, to say that it can't be anything else is false. It could be a jack problem...it would only be apparant when the jack is making contact with a cable. I do think you should test it with another guitar and another cable but if that is not solving the problem then I bet it's a problem with the input jack of the amo itself or even one of the ionternal components (this is a digital amp and there are MANY components and settings that can trigger a problem like this) If the problem is not solved with a new cable/guitar configuration then it's time to take it to the shop.
Line 6 Spider... | Answered on May 14, 2016
Turn the amp off. Hold down the A (or clean) button as you turn on the power and hold the button for 5-8 seconds, then release.
Line 6 Spider... | Answered on Nov 25, 2014
Line 6 does not supply schematics to end users.
After making sure your guitar cable is OK (they often cause the problem) check the inout jack on the amp. They often get broken by yanking cable sideways.
Line 6 Spider... | Answered on Apr 24, 2014
I'm not sure which amp you're playing thru. but generally the settings you want for a clean sound. check your drive (or Gain ) knob. You want it about half way.and your Channel volume, half way. those are good starts. then let your master volume do the rest. Also, make sure, if you have active pick-ups on your guitar. check the batteries. if they're low, it can cause distortion. if this doesn't resolve, then its internal. could be anything at that point.
Line 6 Spider... | Answered on Apr 09, 2014
Chances are the resistance element in the volume control has broken. This is COMMON if the control knob gets smashed some way.
A less common thing would be broken solder where the control is soldered to the circuit board. This would be obvious once the board is accessable.
Servicing involves removing the chassis and replacing the potentiometer.
Line 6 Spider... | Answered on Oct 17, 2013
you need to plug in cord and plug that into wall
Line 6 Spider... | Answered on Sep 05, 2013
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Line 6 Spider... | Answered on Aug 05, 2013
If the damaged component is designated D20 then it is a diode. If it was a resistor it would be marked as R20.There is a copy of the circuit available here http://music-electronics-forum.com/t3077...
Line 6 Spider... | Answered on Mar 26, 2013
Provided that you're not using any external devices, and plugging the guitar directly into the amp, this sound solely like an internal switching problem. Meaning...it will require service. Chips can get faulty like that sometimes. If you're using any external pedals, remove them and see if it happens. If not...the pedal(s) are to blame.
Line 6 Spider... | Answered on Jan 14, 2013
If you can see where the power wiring comes into the amp there has to be a fuse in there somewhere as the fuse is designed to cutoff all power when overloaded
Line 6 Spider... | Answered on May 14, 2012
Is it potentially fixable, but probably not worth it. By the time you have paid for spares and an engineer to fix it it would be more than the amp is worth. If it is within warranty then take it back to the shop. It may well have been a fault with the amp.
Line 6 Spider... | Answered on Sep 15, 2011
It sounds like the speaker may have gone. I have had the same happen to me in the past. Only option is to replace the speaker I'm afraid!
Line 6 Spider... | Answered on Sep 08, 2011
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
91 questions posted
Top Line 6 Music Experts
Michial Gueffroy
Larry Stiles
Larry Stiles
Joaquim Martins
Are you a Line 6 Music Expert? Answer questions, earn points and help others
View Most Popular
Line 6 Music
  • Line 6 Music
Most Popular Question
whenever slightly adjust channel
  • Music
