20 Most Recent Canon iR 2016i Black and White Copier Questions & Answers
My Canon C-IR2016 is demanding a Administrative ID & Password.
I did entered the Admin PWD and latter removed it. but can't really
tell what happen that after I restarted the copier, it still requested for
the Admin ID & Password. unfortunately the the details i used before
is not functioning any more. PLEASE I need Help !! thanks
Canon iR 2016i... | Answered on Jul 23, 2019
Hi, you need to upgrade firmware from start. Download standby is message that appears when system is colapsed and when you want to upgrade firmware from service mode.
Canon iR 2016i... | Answered on Jul 06, 2019
Error message ir2016 download standby
Canon iR 2016i... | Answered on Jul 04, 2019
Check the fixing unite connector
Canon iR 2016i... | Answered on Jun 30, 2019
i have canon Ir2016 it give 808 error code can u help me please
Canon iR 2016i... | Answered on May 21, 2019
That code indicates a problem with the digital counter board
Canon iR 2016i... | Answered on Apr 19, 2019
bonjour j'avais le m?me probl?me avec mon iR2016. Mais j'ai un peu trouv? une solution. Lorsque vous voulez copier plusieurs pages je vous prie de bien vouloir retirer le bac A3/A4 et vous mettez les papiers dans le bac arri?re et d?marrer la copie vous n'aurez aucun bourrage ni Format Papier, ?a va marcher...
Canon iR 2016i... | Answered on Mar 29, 2019
magnet roller poor contact on roller bush connector... other wise roller blade ya roller stick clean properly Nd cheek board connector.. otherwise the magnet roller is damaged... clean the full toner unit...
Canon iR 2016i... | Answered on Feb 28, 2019
Corrupt BOOT ROM ,system software needs to be reloaded to 60.02 or higher.Tech Only
PROBLEM WITH CANON 1R 2016 PHOTOCOPIER
SHOWING ADJUSTING WAITING FOR SCAN
PLEASE HELP ME HOW TO FIX THIS
Canon iR 2016i... | Answered on Apr 06, 2018
As far as I know, Canon IR2016 is stand-alone copier. Printing is optional using Network connectivity. The USB port found at the back is for upgrading purposes only.
Canon iR 2016i... | Answered on Jan 25, 2018
Hi
A website I have found gives the details of this error for the IR2016 and the IR2022 as the same.
Description Low temperature during temperature control.
The target temperature is not reached during temperature control. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Amongst other codes you can find it here:
Error Codes Canon iR2022
Hope this is helpful, if so would you please register that with Fixya
Cheers
Canon iR 2016i... | Answered on Sep 14, 2017
E000007-0000 code is Fixing Film error.
FM2-3346-000
1 FIXING FILM ASSEMBLY 120V
FM2-3353-000
1 FIXING FILM ASSEMBLY 230V EXCEPT CN
FM2-3329-000
1 FIXING FILM ASSEMBLY 230V CN
Canon iR 2016i... | Answered on Jul 14, 2017
E007 means that the fuser film inside the Fuser unit is damaged which needs to be replaced, or the white patch on the fuser film is dirty and it just needs to be cleaned. I recommend getting a canon technician to fix it,
Canon iR 2016i... | Answered on Jun 01, 2017
I'm assuming it is the waste toner full message. Power down copier- Main Power. Open front door and gray handle to open left side door and pull out drum. On the top there should be an opaque disk to be removed and then you can dump the waste toner into the trash. BE VERY CAREFUL THIS COULD GET MESSY.! Slide the drum back back into position, close the left door and front door. Power up the copier and all should be good.
Canon iR 2016i... | Answered on May 08, 2017
The only thing I can think of, without actually seeing it work, is the feed rollers. I've never liked the feed system on this model, seems to be very temperamental. It could also be the feed clutches. There was a modification that should have done years ago dealing with the feed system. I don't know if this applied to the extra two cassettes but the two upper paper pick-up assemblies were to be replaced. Gears were updated.
hi;
you should download a new software, use SST and the new software for IR2016i.
Canon iR 2016i... | Answered on Apr 19, 2017
It is either the drum unit or developer unit or transfer roller. if your counter is 150 000 copies change dev unit and transfere roller.
Canon iR 2016i... | Answered on Mar 26, 2017
Canon iR 2016i Black and White Copier Logo
749 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
machine pausing after making first 2
  • Office Equipment & Supplies
