20 Most Recent Toshiba E-Studio 3511 Color Copier Questions & Answers
Hi how are you this is jack .....(jack_pak@hotmail.com).. my personal ID.
Laser optical unit related service call
[CA10] Polygonal motor abnormality
Is the polygonal motor rotating?
NO 1. Check if the connector CN352 on the LGC board is disconnected.
2. Check if the harness is open-circuited or the connector pin is disconnected.
3. Check if the conductor pattern on the LGC board is short- or open-circuited.
4. Replace the laser optical unit.
5. Replace the LGC board.
YES
Is the printed image distorted?
YES 1. Check if the connector CN352 on the LGC board is almost disconnected.
2. Check if the harness is almost open-circuited or the connector pin is almost
disconnected.
4. Check if the laser unit cooling fan is stopped.
5. Check if the suction area of laser unit cooling fan is plugged up.
6. Replace the laser optical unit.
7. Replace the LGC board.
Thanks
Best Regards,
Toshiba E-Studio... | Answered on Dec 13, 2018
It means that the number of reserved jobs has exceeded 100. You can either wait for the reserved jobs to be completed, or check the jobs and delete the reserved jobs
Toshiba E-Studio... | Answered on Jul 28, 2018
From the Service Handbook:
- Transfer belt marker detection abnormality (normal operation):
- The home position of the transfer belt cannot be detected.
Check if the sensors in the transfer belt are clean, they may be dirty. Check if they are working normally. Also, better if you install bright silver sticker or tape on the reflectors inside the belt.I have experienced that Those reflector get dusty or worn out and sensor can't check them and error occurs.
Open up your Transfer ***'y Unit , Take out the Transfer Belt see if your Silver Marking Stickers behind the transfer belt missing or very dirty.Check the Silver marking censor inside the Tranfer ***'y Unit..it will solved the problem.
Hope helped.
Toshiba E-Studio... | Answered on Feb 25, 2018
You will not be able to, because the primary drivers for the Toshiba E-Studio 3511 Color Copier, are too old for the Mac OS X 10.6 Snow Leopard printer.
As you already may be experiencing, the range of use for your Toshiba E-Studio 3511 may work with various generic drivers and will not improve due to the Toshiba printer's incompatibility with Mac OS X 10.4 - 10.6.
You will in fact, always have a very limited to basic use of this Toshiba Color copier in Snow Leopard, because the driver support stopped at Mac OS X 10.3 Panther and there are not even any drivers for Mac OS X 10.4 Tiger for this Toshiba printer.
Printer drivers for
Toshiba E-Studio Color Copier:
* Windows98/Me/2000/XP/2003 Server (only 32Bit), * * Windows NT4.0,
* Macintosh 9.X, X ver10.1/10.2/10.3
* Unix (HP-UX 10.20/11.X, Sun Solaris 2.6,2.7,7.8,8,IBM AIX, Linux)
Link to Technical Specs page:
Toshiba E-Studio 3511 Color Copier Technical Specifications
If you want review compatible printers for Mac OS X 10.6 Snow Leopard, here is the Apple link for this list:
Mac OS X v10.6: Printer and scanner software
Hope this helps!
Regards,
-Mactechtrainer
Sr. Mac Support Specialist
Toshiba E-Studio... | Answered on Dec 07, 2017
Step 1:- Switch off the machine
Step 2:- Press 0 & 5 simultaneously
Step 3:- Switch on machine.
Step 4:- The display shows test mode.
Step 5:- enter code 200
Step 6:- the machine starts automatic adjustement of auto toner sensor , and when the display shows adjust mode then press enter on the display.
Step 7:- Now switch off & on and check the problem should be
resolved. If problem continues then maybe, changing your
developer may solve the issue.
Toshiba E-Studio... | Answered on Jul 31, 2017
buenas noches quiero sabe como scanear en la multifuncuional toshiba 2330c y hacia que carpeta direcciona los documentos gracias
Toshiba E-Studio... | Answered on Jan 05, 2017
Hello dear: i have a copier machine Toshiba e studio 3511 , and i thing the cdd is fell, how i would do to make work , please can you healh me with the
my name is Edgar
Toshiba E-Studio... | Answered on Jun 18, 2016
try rest the copier by switch on the copier while pressing '0&8"
enter 690 press start button enter 2 press enter key on touch screen, wait till you see 'Reboot the machine: It is communication err.
Toshiba E-Studio... | Answered on Dec 04, 2015
C970 Process related service call High-voltage transformer abnormality: Leakage of the main charger is detected.
[C970] High-voltage transformer abnormality (1) Is the main charger installed securely? (2) Check if the spring of high-voltage supply contact point is deformed. (3) Check if the charger wire is broken or the main charger grid is deformed. (4) Check if any foreign matter is on the charger wire or main charger grid.
Toshiba E-Studio... | Answered on Jun 23, 2015
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Toshiba E-Studio... | Answered on Jan 20, 2015
I have seen several of these older models get stuck in "warming up please wait" mode due to bad hard drive. I have also seen same message caused by the electrical with insufficient amps.
Toshiba E-Studio... | Answered on Nov 27, 2014
Toshiba E-Studio 3511 Color Copier Logo
290 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
job reservation full
  • Office Equipment & Supplies
