20 Most Recent HP LaserJet M1522nf Multifunction Printer (CC372A) Questions & Answers
HP Laserjet M1522nf Update 7 drivers
HP LaserJet... | Answered on Sep 01, 2019
try finding a utube video on the subject there shud be vids on someone else who has done the fixing as well , anything else you need you can find it here>>www.discountbargainprices.com
HP LaserJet... | Answered on Feb 17, 2019
sounds like might be your toner, specifically your black toner.
is this a non-standard toner or HP? IF it your toner you can try this:
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site. http://www.infinityimaging.com/cgi-local/SoftCart.exe/online-store/scstore/p-2300.html?E+scstore
otherwise it's probably the memory on the printer, try removing or replacing a DIMM
HP LaserJet... | Answered on Jan 24, 2019
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
HP LaserJet... | Answered on Oct 19, 2018
REPLACE FUSER.
HP LaserJet... | Answered on Oct 10, 2018
Try a nvram. While the printer is off, hold down the down arrow and the cancel button and turn the printer back on, hold down until permanent storage init is displayed on the lcd.
Al
HP LaserJet... | Answered on Sep 03, 2018
u go to settings of printer in which check the default print.
HP LaserJet... | Answered on Mar 27, 2018
You can try setting the printer back to fabric settings following this simple steps:
1) Turn the printer off
2) Now while the printer is off, press and Hold the down arrow and cancel button
3) Keep them depressed and turn the printer back on while holding those keys
4) you will see a message on the display that reads "permanent storage init" at this point you can release the buttons
After this steps you need to wait about 3-4 minutes and then the printer will come back to ready
Password reset DONE !!
If you need more assitance you can contact me at :
eliteprintersolutions@gmail.com
HP LaserJet... | Answered on Feb 17, 2018
Give a call to HP Support to get the issue resolved (877-690-9305)
HP LaserJet... | Answered on Feb 02, 2018
HP LASERJET M1522 NF MFP PRINTE Printer
where is the chip brain, I want to fry it !....It's so dump printer !
When you changed from Network to USB cable, one or both of two things may have occurred.
First check your printers list in the control panel. You may find you have two apparent installations of the device. If so try a test page from each install and record the port settings for the one that responds. Delete the other and re-test. If the machine fails to print on any setting, delete ALL installations for the device and re-install from fresh with the USB cable. You may also need to go into the settings on the device itself and disable any network settings.
HP LaserJet... | Answered on Oct 16, 2017
See my tips section for the solution to this. This error is covered by HP and they will repair at no charge for almost all M1522's ever made.
HP LaserJet... | Answered on Oct 14, 2017
Tip
EPSON PRINTER SUPPORT
USA-printer-support is the best printer service provider company. We are providing exceptional support when problems occur in Epson printer problem. Epson printer support phone number proves out to be the most dependable source for fixing all technical with Epson printer device. Our tech support team will be gives best services to your when you will call to me related Epson printer related problem. Our services are available 24*7. EPSON PRINTER SUPPORT NUMBER +1-800-978-0818. To get more details visit our website.
http://www.usa-printer-support.com/epson-printer-support
on Jun 23, 2017 | HP LaserJet M1522nf Multifunction...
Fix for HP LaserJet error 49
HP LaserJet... | Answered on Jul 01, 2016
software download for M1522nf to new windows 7
HP LaserJet... | Answered on Jun 30, 2016
Depending on the printer, remove the cartridge and then the print head under it. Run it under hot water until the water runs clear. Dry with kitchen towel and the on the computer go to printer properties and run a clean cycle, then run a test pattern. Also check that your paper is dry. Better quality paper produces better quality prints.
HP LaserJet... | Answered on Nov 20, 2015
if it is frozen on boot, you need to replace formatter or warm its chip until 280°C for 20-30 seconds.
HP LaserJet... | Answered on Sep 16, 2015
this error can be caused by a paper jam, or a little piece of paper in the toner area, Take the cartridge out and use a flashlight to check in the sides looking for paper. Other reason is that sometimes the sensor that detect the toner is out of place and in that case you can try to power cycle with the toner out before you install it again. Good luck
HP LaserJet... | Answered on Sep 12, 2015
please check that u select the proper printer before preceeding for print command. Also check that the printer connected to ur system is ur default printer.
HP LaserJet... | Answered on Jul 07, 2015
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
585 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
gives bang sound when powered cartridge
  • Office Equipment & Supplies
