20 Most Recent HP LaserJet M1522n MultiFunction Printer Questions & Answers
Baking is a waste of time. Formatters are not that expensive. Call 1-800-parts-now.
HP LaserJet... | Answered on Apr 07, 2019
go to www8.hp.com and get the support via ONLINE chat free for fix
it the error # 5.
God bless you
HP LaserJet... | Answered on Sep 14, 2018
Step 1.Switch on the machine observe Optical scanner assm moving forward & reverse for checking home position? remove flat bed glass,clean it especially at black band area, fix it and check..Step 2. Switch off the machine, remove power cable, remove left side door,dis connect Scanner cable(connector J4) on formatter, switch on the machine, check if same error? replace formatter assm..if different error replace optical scanner(CCD) assm..
HP LaserJet... | Answered on Aug 08, 2017
Looking for hp printer customer service phone number 1877-778-8@9@6@9 anytime. For further Info Click: https://goo.gl/F3Ta5j
HP LaserJet... | Answered on May 11, 2017
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
eliteprintersolutions@gmail.com
HP LaserJet... | Answered on Jun 03, 2016
HP Support ->link.
HP LaserJet... | Answered on Apr 25, 2016
This is entirely software based.
The stub app is part of the software that helps the computer/laptop communicate with the printer.
My first bit of advice would be to go to HP's support site and download the new software or re-install the software from HP website
HP LaserJet P2035 Printer
Please note when I say re-install I mean uninstall the older software first and then re-install the new downloaded software.
  1. In Windows Vista/7 (Click on the start button).
  2. In the search box type in programs and features (look above and select uninstall a program).
  3. Select every single bit of software related to HP Laserjet and uninstall this one by one.
  4. Download the software from the link above, restart the computer and re-install the Hp Printer software (Do not keep the printer plugged into the computer or powered on).
Should you still require more help respond to this and I'll help you further.
HP LaserJet... | Answered on Apr 21, 2016
You have a bad toner cartridge. All HP toner cartridges have chip attached to them. That chip is read by a sensor in the printer. If the chip is missing or bad replace the cartridge.
HP LaserJet... | Answered on Aug 22, 2014
Find the numbers on the inside of your printer,it has the numbers of any type of ink you may need to add. All of the newer printers have a number on them and they don't come with all the colors you may use.
HP LaserJet... | Answered on Jun 09, 2014
A 50.3 error means that the temperature of the fuser got to high.
Just try switching it of for 20 minutes and try again.
If it happens during a large print job, this may help, if the error returns when powering up the machine, the fuser is faulty, but if so, that means it would have to be replaced.
If you are printing narrow media (A5, envelopes) etc. try printing them in small batches,, and allow the printer to cool of in between batches.
HP LaserJet... | Answered on May 26, 2014
remove the right hand side end cover ( formatter acces panel) remove the bad memory ( card about 1" by 3" )- if your not sure its failed try with new memory and see if error returns
HP LaserJet... | Answered on Mar 04, 2014
If USB cable is good , and your USB port is good , maybe the formatter port problem
HP LaserJet... | Answered on Apr 02, 2013
Try another toner. Most likely the chip on this one is bad.
HP LaserJet... | Answered on Mar 14, 2013
49 Error, Turn off then on
The product has experienced an internal embedded software error.
Turn off the power by using the power switch,
wait at least 30 seconds, and then turn on the
power and wait for the product to initialize.
If the error persists, contact HP. See
www.hp.com/support/ljm1522 or the support
flyer that came in the product box.
HP LaserJet... | Answered on Feb 14, 2013
HP LaserJet M1522n MultiFunction Printer Logo
133 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
error 50 2 hp m1522n turned off but
  • Office Equipment & Supplies
