20 Most Recent Canon PowerShot SD1100 IS Digital Camera Questions & Answers
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
Canon PowerShot... | Answered on Oct 31, 2017
So your power shot has gone south. Shame because they are really good cameras. Unless it is a very ex[pensive model repair is never cost effective.
Canon PowerShot... | Answered on Aug 28, 2017
There is no built in speaker in Polaroid iS426 camera. You can play your videos when imports on your PC. So don't worry about that.
Thanks
Fazal Zahoor Bangash from Pakistan
Canon PowerShot... | Answered on Apr 04, 2017
A quick look on Cnet reviews says the specs for battery and power are:
Power
  • Power Device Battery charger - External
Battery
  • Supported Battery Canon NB-4L
  • Supported Battery 1 x Canon NB-4L Li-ion rechargeable battery ( Included )
An NB-4L battery charger is what you need to charge the battery for that model. My Canon charger is a small box with fold out wall socket prongs and a mount for my battery to slip into.
This looks like a Generic version sold on eBay, that includs a Euro/mexico Socket adapter.
Canon PowerShot... | Answered on Dec 30, 2016
cost will exceed what a new camera would cost probably .
Canon PowerShot... | Answered on Jun 21, 2015
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Canon PowerShot... | Answered on Nov 25, 2014
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Canon PowerShot... | Answered on Nov 07, 2014
Canon PowerShot SD1100 IS Digital Camera will cost you around $258. If you want to buy it online, you can visit this link.Thanks for using Fixya.Good Luck and have a nice day
Canon PowerShot... | Answered on Feb 27, 2014
I have had success with this... Download this camera photo recovery program
http://www.facebook.com/pages/Asoftech-Photo-Recovery/126127714100611?sk=info
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Canon PowerShot... | Answered on Nov 22, 2013
You can run a check on that memory with Active File recovery to see if the pictures are there or not. If they are there you can get them back.
The free demo o this software allows only file smaller than 64kb to be recovered or you can use the online version which might not have the limitation but it might not see he memory stick not even if the camera is connected to the computer. There's possibility thought that it might see it if you connect it before starting the online version, the demo should see the card if it's connected.
http://www.file-recovery.net/
Canon PowerShot... | Answered on Nov 19, 2013
Cameras and beaches don\'t do well at all. The most important thing is to remove as much sand as possible without scratching any part of the camera. I\'d suggest to not wipe it at all, but take it home and try to vacuum the sand and dust off. It can get wedged in the drive mechanism for the lens focusing and will stop the camera from going through its normal initialization cycle. Check around the edges of where the lens moves in and out for sand, and try to suck it out.
Canon PowerShot... | Answered on Nov 17, 2013
You can download it from Cannon, support,downloads, choose model. This is horrible software by the way. Once you have the basic driver for your model installed(Windows has many drivers pre-installed for many cameras), you are better off using MS picture and fax viewer. It does not have the lengthy and overly complicated stuff that comes with the camera. Anything that comes with the camera for free is usually junk written by grad students to practice their software engineering.
Canon PowerShot... | Answered on Nov 16, 2013
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but eventually will corrupt.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for.
You will need to use a flash card reader with this software. If you don't have one, get one, they're inexpensive.
Finally, AFTER you've recovered the photos, format the card in your camera to prevent this from happening again. Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Canon PowerShot... | Answered on Nov 05, 2013
Canon PowerShot SD1100 IS Digital Camera Logo
550 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
memory card canon power shot sd1100
  • Cameras
