20 Most Recent Nikon Coolpix S210 Digital Camera Questions & Answers
service camera at Nikon. mechanical SD card lock failure
Nikon Coolpix... | Answered on Nov 25, 2017
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Nikon Coolpix... | Answered on Oct 04, 2017
Basically that will be extremely expensive, and probably not worth it. Resign yourself to the fact that the camera is fubar, and replace it with a newer model. Remember NOT to get sand in this one.
Nikon Coolpix... | Answered on Oct 03, 2017
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Nikon Coolpix... | Answered on Dec 13, 2015
In general there is information you CAN see WHILE you are taking photos. You can select if you want this information shown while you take photos. The battery info is part of this information. If you need more help look at your manual.
Nikon Coolpix... | Answered on Sep 02, 2015
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Nikon Coolpix... | Answered on Oct 04, 2014
The best way to transfer pictures from a camera with an SD memory card is to do it outside the camera. If your computer does not have an SD card reader built in, you can buy an external USB card reader for $20 or less on E-bay, Amazon, etc. Remove the memory card from the camera and insert it in the card reader. Your computer will treat the card reader and SD card just like it treats an external hard drive. Either drag-n-drop or copy and paste your pictures from the SD card file to a file on your hard drive. If after you have copied and backed up your files you want to reformat your SD card, replace it in the camera and format it in the camera, not in the computer. SD cards formatted in a computer will often not work in your camera because of slight differences in the formatting.
Nikon Coolpix... | Answered on Aug 26, 2014
you should take it do the shop because somthing might be stuck or it could have a malfunction well i dont no exactly i jus say go check it out
Nikon Coolpix... | Answered on Aug 07, 2014
Take the battery out and recharge it or if triple A replace them.
Nikon Coolpix... | Answered on Jul 29, 2014
You can download drivers for your computer from the Nikon website. Click the Service and Support tab. You will see a link called "update your camera's firmware." Click it and find your camera.
Nikon Coolpix... | Answered on Jul 27, 2014
First of all, you upload pictures to your computer (you are putting pictures into the computer, not taking them out; downloading). Make sure that your computer's plug-n-play module recognizes that your camera is attached. Depending on if you have a Mac or PC, you may need to download and install a new driver for your computer from the Nikon website. I never connect a USB cable from my camera to the computer for uploads. Instead, I take the SD memory card out of the camera and insert it in the card reader on my iMac. If your computer does not have a built in card reader, many brands of external card readers are available at very low prices on line.
Press the MENU button, select the wrench icon, press the OK button, select "Time zone and date," then press the OK button. See page 98 of the manual: http://download3.nikonimglib.com/archive1/ZagNQ00rvnhI0044PB151zvANH63/S3500RM_(En)02.pdf
Nikon Coolpix... | Answered on Jul 08, 2014
Nikon Coolpix S210 Digital Camera Logo
646 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
broken lcd screen
  • Cameras
