20 Most Recent Toro Lawn Mower With Toro Power Tools Questions & Answers
carb is probably dirty. an out of adj governor will make it rev high.
Toro Lawn Mower... | Answered on Nov 02, 2018
make sure your tires are at proper pressure first. then you can google how to adjust the drive linkage.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure. Here is the
link -
Best Manuals
Toro Lawn Mower... | Answered on Sep 17, 2018
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Toro Lawn Mower... | Answered on Jun 11, 2018
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Toro Lawn Mower... | Answered on May 31, 2018
Most gas mower carburetors have a tiny hole for the fuel to rise into the vacuum venturi throat of the intake. The hole in this riser tube which goes down the center of your float chamber to the area where the fuel sits in the bowl is only as big as dental floss. Take the tine of a wire brush to clear it of crystallized or varnished gasoline and oxidized pot metal tube crust. When they make stainless carburetors, it will eliminate half of the heart attacks caused by this problem. Additives and condensation that settle out in old gas also can lead to clogging.
Toro Lawn Mower... | Answered on Apr 25, 2018
take it to toro they know how it works , if that New they may fix under warranty
Toro Lawn Mower... | Answered on Feb 21, 2018
battery or cable problems
When using the battery , there is insufficient power left to run the ignition system
when pull starting what is in the battery is sufficient to start the engine
Find an identical model on eBay for a lower price than a new mower, and use it for parts, or switch parts if the eBay model is in better condition.
Since it is from 1987 before many of us were born, as stated in the Star Trek tv show, "Its Dead, Jim."
Toro Lawn Mower... | Answered on Feb 20, 2018
Sounds like the adjustments need to be worked on outside the carb. If they are dry put a little bit of light oil or even WD40 on all the moving parts on the carb. Sometimes they just get dry and a little rusty from sitting.
Toro Lawn Mower... | Answered on Feb 17, 2018
Clean the carb. The old gas gunked up the orifices.
Toro Lawn Mower... | Answered on Feb 15, 2018
i dont know your model but most drive belts are located under the seat you may have a tenson spring problem
Toro Lawn Mower... | Answered on Jan 30, 2018
overhaul the carby , paying to something holding the needle off the seat and flooding the engine
Toro Lawn Mower... | Answered on Jan 28, 2018
check fuel in the tank
check for blocked filter in the tank
check for full fuel flow to the carby
overhaul the carby
Toro Lawn Mower... | Answered on Jan 09, 2018
Sounds like the mechanism needs to be readjusted. Does not open it quite far enough.
Toro Lawn Mower... | Answered on Dec 28, 2017
did mice get in there during the Off Season? Check for Mouse nest or rust on Coil and magnet section of Flywheel.
No, no points.
Toro Lawn Mower... | Answered on Dec 24, 2017
The drive belt is off the pulley, you will need to check under the deck and possibly remove the cover on top of deck to put it back on.
Toro Lawn Mower... | Answered on Nov 19, 2017
best guess , blocked main jet or water in the carby
an overhaul would be in order
Toro Lawn Mower... | Answered on Oct 24, 2017
Sounds like the belt might possibly be stretched from use. The spring on the tightener might have broke also. Take the side panel off and check.
Toro Lawn Mower... | Answered on Oct 02, 2017
Toro Lawn Mower With Toro Power Tools Logo
1,442 questions posted
Top Toro Garden Experts
Jim Parker
Jim Parker
lnbn1975
roeb
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
toro 6 5 gts start after taking blade
  • Garden
