20 Most Recent Electric Lawn Mower Questions & Answers
Turn it over and clean the caked grass off, then
try it.
Electric Lawn... | Answered on Oct 12, 2019
Please give make and model to further assist you.
Electric Lawn... | Answered on Jul 01, 2019
Look it up in the Manual:
https://www.manualslib.com/manual/1042217/Bosch-Asm-32.html
Electric Lawn... | Answered on Apr 24, 2019
charger for same does not show any lights..so should i assume the charger is not working?
Electric Lawn... | Answered on Jun 03, 2018
Open your circuit breaker box. Locate the breaker that has tripped. Turn the breaker OFF (it is in a mid position). Then turn it back ON. Before you do that you need to ask yourself, why did the circuit breaker trip? They trip because of an overload of current. Is something else running on that same circuit, say for example an electric heater or something similar? Depending on the rating of that circuit breaker (15 or 20 amps) you may be drawing too much current. Look for anything else that could be running on the same circuit (only so many outlets can be put on the same circuit). Disconnect or turn off all other devices. Attempt to operate your mower again. If the breaker trips again, then there is something wrong with your mower (electrical short?).
Electric Lawn... | Answered on Nov 29, 2017
guess you have to find a mechanic that can weld what you roke or make a new piece if the company does not make them anymore
Electric Lawn... | Answered on Aug 21, 2016
get gas mower best fix
Electric Lawn... | Answered on Apr 21, 2016
Try this blog site it is all about Black and Decker CMM 1000 and CMM 1200 mowers. Marks Electric Mower
Electric Lawn... | Answered on Jan 27, 2016
According to wikipedia. a commutator is the moving part of a rotary electrical switch in certain types of electric motors and electrical generators that periodically reverses the current in a DC motor. It's part of what makes the motor run.
A commentator HOWEVER, is a person who comments or expresses an opinion on a subject.
Electric Lawn... | Answered on Jul 15, 2015
Pull the plug. MAKE SURE THE PLUG IS COMPLETLY REMOVED AND SEPARATED FROM THE MOWER!! Remove the cover with the pull start attached. see if you can turn it by the flywheel or the blade. If you can, you can just have the rewind repaired.
If not, then you have a probable bent or twisted crankshaft. Most likely not worth repair.
no doubt the brushes have decided they need replaced .
Electric Lawn... | Answered on Apr 06, 2015
It sounds like bearings are seized and need to be replaced. Too much attempted use will burn out the field windings and a rewind or new motor will be needed - both costly.
Electric Lawn... | Answered on Dec 06, 2014
If you still have it, one of the possible fixes for this is cleaning the contacts in the switch box. Make sure the battery is unplugged. Remove the top handle by unscrewing the big yellow knobs on the sides of the handle. Remove the cable from the top cable clip. Turn the switch box over and unscrew the 5 screws. Taking the box apart you will be able to see where the cable comes in and splits into 4 leads, two white and two black. Pull the switch out and unplug the 4 lead clips from the switch prongs. (Take note that with the 4 prongs up and the switch pointing to the left, the 2 white leads will be on the left and the two black leads on the right.) Now turn the switch over to where you see the two screws. After removing the screws you can pop the switch apart. You will likely see rust on the springs, and a patina on some of the copper contacts and prongs. Spray the inside with some WD-40 to treat the rusted area wiping with a paper towel afterward and drying. Then use a piece of sand paper to clean your contact points and the prongs on the back. After the points are cleaned, put the switch back together and replace the two screws. Reconnect the wires to the switch. You can now test to verify if you have succeeded by depressing the switch while the battery is connected. If this works, then disconnect the battery and put the switch box back together on the handle. Reconnect your top handle and your are done. Good luck! I just repaired mine today when I realized this is why it had not been working.
Electric Lawn... | Answered on Sep 07, 2014
sound like you got some burn wiring ether in the handle or down in the lawn mower probably have to take to shop
Electric Lawn... | Answered on Jul 07, 2014
needs new set of brushes in motor
Electric Lawn... | Answered on Jul 05, 2014
Most electric motor problems are caused by the bearings failing. Before that happens it may get very stiff but stil turn. With the power off, and the blade still attached, try turning the blade at least half a turn. Is that possible? Any noises as you turn? Is it very stiff or fairly free? If you turn it several times you may find that putting it upright and connecting the power it may start turning again.
Let me know what you find.
Electric Lawn... | Answered on Jul 04, 2014
cable damaged ...renew cable . ..if does not work try condenser.
Electric Lawn... | Answered on Jul 01, 2014
Electric Lawn Mower Logo
149 questions posted
Top Electric Garden Experts
Steve Oakes
Steve Oakes
dannydoesita
sgtstrat
Level 1 Expert
Are you an Electric Garden Expert? Answer questions, earn points and help others
View Most Popular
Electric Garden
  • Electric Garden
Most Popular Question
remove top bosch asm 32f lawnmower
  • Garden
