20 Most Recent Yahoo Messenger Questions & Answers
Hello there Roda,
You cannot change your yahoo ID unless you apply for another account.
However, you can add up to six (6) aliases to your current ID as part of thesame account. An alias consists of a name and some information that youshow in a profile to other members. When you log in to Yahoo!, you canchoose any of your aliases.
For further instructions, click this yahoo page:
http://help.yahoo.com/l/us/yahoo/edit/changing_users/edit-04.html
Good luck and I hope this helps.
Yahoo Messenger | Answered on May 21, 2019
You'll need to use the entire rocketmail address, so it'd be something like "yourname@rocketmail.com" instead of just "yourname".
Yahoo Messenger | Answered on Apr 22, 2019
Good Day Kylenergizer!
If you can not remember your Yahoo Mail password, then, there is no way you can gain access to your mail account.
And if you want to gain access on your Yahoo Mail account, the only possible way is to reset your forgotten password.
Please follow this procedure and answer the questions correctly. The questions are to verify that you are the real owner of the Yahoo Mail account. At the end of this procedure you will be able to reset your old password and create a new one.
1. Go to https://edit.yahoo.com/forgot?stage=fe100&src=ym&intl=us&done=http://mail.yahoo.com&partner=
2. Enter your email address or Yahoo! ID, inside the box, next to "My Yahoo! ID is"
3. See the code - a series of letters and numbers, enter it inside the box, next to "Enter the Code Shown"
4. Click the Next button.
5. Enter into the box the answer to the question 1, then click Next button.
6. Enter into the box the answer to the question 2, then click Next button.
7. Enter your new password and retype it for confirmation.
The next time you log in to your Yahoo Mail account, please use your newest password.
Enjoy Yahoo!
Please comeback and don't forget to rate my answer.
Thank you for asking Fixya.
Yahoo Messenger | Answered on Mar 11, 2019
not suspended? it's in-active mail?
try it here
Yahoo! Answers Appeal Form
http://help.yahoo.com/l/us/yahoo/answers/first_appeal.html\
http://help.yahoo.com/l/us/yahoo/answers/index.html
or here if you have info about the last setting
https://edit.yahoo.com/&src=ym&partner=&intl=us
Yahoo Messenger | Answered on Mar 10, 2019
1) Try clearing your browser cache
Tools > Internet Options > General Tab
Press Delete Button
Uncheck Preserve Website Favorites Data
Check all other options available
Press Delete Button
Wait for Windows to delete cache files
Press Ok
Retry login
2) Reset IE Browser
Tools > Internet Options > Advanced Tab
Press Reset Button
Check delete personal settings
Press Reset Button
Click Ok
Reboot for changes to take effect
Retry login
Yahoo Messenger | Answered on Feb 25, 2019
I'VE GOT IT!
Whether you are using XP or Vista, go to System Restore, follow the instructions and you will be taken to a point in the past that you either a) didn't have a Messenger hang or b) before installed Messenger and then you can do it again.
It doesn't affect any documents.
I should have remembered this myself but one of the guys on a forum that I am a member of reminded me of this solution.
Go to it...it's cake.
Yahoo Messenger | Answered on Feb 13, 2019
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
If u want to give up yahoo
u need to delete entire account
visit Account Deletion page.
https://edit.yahoo.com/config/delete_use…
u will be asked to sign in to or verify ur
password for the account u wish to delete.
after the deletion process is initiated,
ur account can never be recovered
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Yahoo Messenger | Answered on Jan 25, 2019
Try this, it might help you, click the link to view my solutions
http://www.fixya.com/support/r5025589-easiest_way_solve_yahoo_messenger
Please comeback and rate this.
Thanks
Yahoo Messenger | Answered on Nov 04, 2018
Hello there, This information from yahoo might help you:
To change your password:
  1. From the Yahoo! Home page, click on your user name in the upper right.(You will need to be signed in already)
  2. From the drop down select Account Info
  3. You will be asked to sign in again to enter your Account Info page.
  4. Click Change your password
  5. You will be taken to a page that will look like the one below.
  6. Enter your current password.
  7. Enter and confirm your new password.
  8. Click Save. You will see a confirmation page when you have successfully changed your password.
  9. Click Continue.
Your Yahoo! password always applies to your entire Yahoo! account. This means that it is valid not only for Yahoo! Mail but also for Yahoo!'s other personalized services like :
  • Yahoo! Messenger
  • Yahoo! Chat
  • My Yahoo!
  • Yahoo! Finance
Note: If you are having difficulty logging into your account or believe your account may have been compromised please request a new password
Hope this helps! Thumbs up if it does!
Yahoo Messenger | Answered on Aug 02, 2018
If you have multiple yahoo ID's and wants to login with more than one yahoo ID at the same time then don't worry, you can login with more than one yahoo ID at the same time using this tip. There is no need to install any other yahoo multi messenger version, you can easily covert your normal yahoo messenger into multi messenger and enjoy your many ID's at the same time.
Follow the given steps to change the yahoo messenger registry value:
i)Click Start button and type regedit in Run option then press  Enter:
  Here locate the location to:
ii) HKEY_CURRENT_USER/Software/Yahoo/Pager/Test
iii) Here in right side panel, right click to create a new Dword value with name Plural and give value 1
iv) Now close the registry editor and restart your computer after any changes to go into effect.
v) For signing in with new YAHOO ID open another messenger(multiple)v open as many messengers    you need.
vi) If you want to disable the multiple messenger option then again open registry editor and change         Plural value 1 to 0.
Thanking you
M. Sridhar
Yahoo Messenger | Answered on Jun 28, 2018
According to me you can use "Forgot Password" option to reset your password (you will need to answer your security question or to provide alternate email address to send password reset mail). If still you are not able to reset password (with "Forgot Password" option) then you can use messenger password recovery software (click http://lmgtfy.com/?q=yahoo+Password+Recovery+stellar to search) to recover it.
Yahoo Messenger | Answered on May 03, 2018
Yahoo! is a free customizable website that includes free tools such as email, games, sports and chat. When you forget your password, you cannot utilize tools or access your Yahoo! Mail. Yahoo! has a recovery system that allows its users to reset their password by retrieving it through an alternate email source or by answering security questions. Update the email and security questions regularly in order to prevent account loss.
Reset Your Password Through Email
1.Click "Forgot You Password" on Yahoo! Messenger or "I can't access my account" on the Yahoo! Mail login page. Your browser will take you to the Yahoo! password-recovery page.
2.Select the button next to "I forgot my password." Click "Next."
3.Enter your Yahoo! user name and enter the security code into the "Enter the code shown" field. Click "Next."
4.Enter your alternate email address. Your alternate email address is the address you listed when registering for a Yahoo! account. Click "Next."
5.Check your email. Yahoo! will send you a message to reset your password.
Reset Your Password Without E-mail
4.Click "I cannot access any of the above" and click "Next."
5.Enter the answer to the first security question. These questions were previously set when you created your Yahoo! account. Answering these questions proves to Yahoo! that this account belongs to you. Click "Next."
6.Enter the answer to the second security question and click "Next." Yahoo! takes you to a new page that allows you to reset your password.
7.Enter your new password and then retype it. Click "Next." Your password is recovered.
Yahoo Messenger | Answered on Apr 25, 2018
To Get In The chat room , You age should Have to be 18 or above ,,,, If it is below 18 Your chat request gets refused
If You want get into the chat room , MAke A new email Id and Keep Your age 18 or above ,,,
AFter doing this you can get into the chat rooms
Make sure your browser is up to date and clean it every couple of days with Ccleaner
Yahoo Messenger | Answered on Mar 17, 2018
yahoo messger downlouding probelm how to contac other computer
Yahoo Messenger | Answered on Mar 08, 2018
clean your cookies. https://help.yahoo.com/kb/SLN27197.html
Yahoo Messenger | Answered on Jan 30, 2018
Kirim pesan ke Yahoo email support. Mereka dapat membantu Anda. Gunakan nomor lokal Anda atau terjemahkan pertanyaan Anda ke bahasa Inggris.
Sempre Fi,
Z
Yahoo Messenger | Answered on Jan 29, 2018
Yahoo Messenger Logo
8,642 questions posted
Top Yahoo Computers & Internet Experts
micky dee
Mike
Steve Allison
Steve Allison
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Yahoo Computers & Internet
Most Popular Question
add rocketmail id in yahoo messenger
  • Computers & Internet
