20 Most Recent Samsung L210 Digital Camera Questions & Answers
Hi, you may try to recover your photos from you camera.
1. connect your camera's memory card to computer using card slot on computer or a card reader.
2. downloand an useful photo recovery tool, here I recommend you to use asoftech photo recovery program http://www.asoftech.com/apr/
3. launch it, select the SD card in left list and click "Start" to start the automatic scanning process.
4. and then choose the photos you want to recover from the list of all recoverable photos and click "Recover".
Samsung L210... | Answered on May 16, 2019
it has a technical problem you should go to a person who repairs
Samsung L210... | Answered on Feb 15, 2019
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa.
Organize edit and share your photos
Samsung L210... | Answered on Nov 22, 2014
lower the shutter speed
Samsung L210... | Answered on Oct 24, 2013
Ifyou hear a noise from the lens when you try to take picture or During turnon/off time then it's a lens guide pin problem OR Somehow its jammed ordamaged. It's happens when the camera pressed or drop down during turn on modeor long time not use.This problem happens because of long time no using/ Dust or Lensguide pin damaged after drop down. If the lens guide pin damage then there isno chance for repairing . Only solution is replacing the lens.For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if the camera does not start working thenyou need to visit service center for replacing the Lens or Repairing. Butbefore repairing ask service center the approx cost. if they told you toreplacing the lens then do not do that. Because a new lens & service chargecost you near about a new camera price. So best is buy a new camera. If youhave any more questions ask me I fell happy to answer your question. Thank you.
Samsung L210... | Answered on May 23, 2012
Are your batteries good? Bad (old) batteries can cause problems in operation of any device, even if they appear full. Else, is your memory card ok? Try formatting the memory card on your PC, see what happens then. Last thing that comes to my mind is that you could check the camera's manual, maybe there's some way to reset it completely, that might also help!
Samsung L210... | Answered on Sep 01, 2011
Sometimes the LENS can get stuck inside of it or outside of it. I would wiggle the lens around a little bit, putting a bit of pressure on it while doing so and see if that fixes it. Make sure you're attemping to turn the camera on while doing this.
Samsung L210... | Answered on Apr 05, 2011
Try gently cleaning your lens and flash with a clean dry t-shirt or a cotton earbud. This it doesn't fix the prob check what Function you have the setting on - you may have it on Aperture or Shutter or Manual Priority Mode and what you are getting is camera shake (the shutter staying open too long for you to hold it steady. Try it in Automatic Mode. If this is the case it does not explain why the flash is not working - unless you have set it to under/over expose...... look for a flash sign (like lightning) with a +/- by it. If you press it a little ruler will appear l---l---l---l---l looking something like that with a little block that can be moved. If the little block is not in the center it will be either over exposing or under. Hope this helps! H
Samsung L210... | Answered on Dec 31, 2010
You probably still have a lens problem...try these:
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Samsung L210... | Answered on Nov 26, 2010
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Samsung service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Samsung L210... | Answered on Oct 09, 2010
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Samsung L210... | Answered on Sep 10, 2010
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Samsung L210... | Answered on Sep 03, 2010
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP02&prd_ia_cd=04010400&prd_mdl_cd=EC-L210ZBBA%2FUS&prd_mdl_name=SAMSUNG+L210&prd_ia_sub_class_cd=P
searched FAQ's and found nothing referring to the charger's light.
searched troubleshooting and found nothing there.
http://downloadcenter.samsung.com/content/UM/200902/20090202154546203/L210_English.pdf
p.14 says the orange light means the battery is charging.
Samsung L210... | Answered on Jul 30, 2010
are you shure that you dont have dropped on the camera....
why any time a pressure on the camera can broken the lens dispositive..and the if you turn on the camera she dont can open the lens and turn of.
but to first you must are shure that your batteries are early charged.. that you dont have a foul batteries,,,you think that is conpletly charged but the batteries is not. if the batterie is caharged and the camera blinks and dont turn on ...i am sorry but i think this is a lens or motherboard problem.
Samsung L210... | Answered on Jul 25, 2010
Samsung L210 Digital Camera Logo
30 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
