20 Most Recent Sony BRAVIA KDL-46W4100 46 in. LCD HDTV Questions & Answers
T'Con board fault.
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sony BRAVIA... | Answered on Feb 02, 2018
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony BRAVIA... | Answered on Sep 02, 2016
Sony BRAVIA... | Answered on Mar 01, 2016
This is most likely the inverter board
Sony BRAVIA... | Answered on Feb 29, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sony BRAVIA... | Answered on Dec 25, 2015
Try shopjimmy.com
Sony BRAVIA... | Answered on May 08, 2015
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sony BRAVIA... | Answered on Nov 23, 2014
If you are not afraid of taking the tv apart you can check the connections of the ribbon cables and check to see if you have any swollen capacitors. If these look good your control board may be going out.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Sony BRAVIA... | Answered on Nov 22, 2014
This is generally a sign of a failed power supply and the repair will likely require a technician to locate the failed parts which are most often cheap electrolytic capacitors.
You can try pulling the AC plug overnight and try it again the following day.
All modern sets have complex integrated circuits and these may lock up on occasion.
Removing power overnight may allow it to recover.
Sony BRAVIA... | Answered on Sep 06, 2014
You need 4 screws to fix base stand with tv, part number is as follows:
258060801... SCREW, +PSW M5X16
Available in PartStore.com for $5 each, click that link to view screw image and price info.
AC cord part number is as follows:
183514311... Cord AC
Available in PartStore.com for $13
Hope this will help you.
Thanks.
Sony BRAVIA... | Answered on Feb 06, 2014
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Sony BRAVIA... | Answered on Dec 03, 2013
Sony BRAVIA KDL-46W4100 46 in. LCD HDTV Logo
81 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony bravia will not turn will not
  • Televison & Video
