20 Most Recent Sansui HDLCD3210 32 in. LCD TV Questions & Answers
you have to mention your exact model but according to Sansui, LCD TVs can play DivX and Mpeg4 format files
Sansui HDLCD3210... | Answered on Sep 15, 2019
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Sansui HDLCD3210... | Answered on Feb 04, 2016
sounds like a Parental Guidance lockout, check the settings on the TV preferences menu and turn off Parental Controls, you will need the TV Handset
Sansui HDLCD3210... | Answered on Jan 21, 2016
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sansui HDLCD3210... | Answered on Aug 27, 2015
Check your power supply for proper operation. Look for burnt resistors, bad diodes, leaking or bulging capacitors. If time permits check as many of the parts that you can on that board.
If you check out ebay for that tv set, often you will find parts listings for the set at a much better price.
My guess is you're in the line input of the vcr section. On the remote there should be an input button, Try pressing it until you are in antenna or tv mode.
Sansui HDLCD3210... | Answered on Feb 02, 2015
change source to AV or HDMI or RGB or Component or USB and try
Sansui HDLCD3210... | Answered on Dec 18, 2014
Now u turn on the tv the tv pictures only flashes a few sec.than dies,but the tv still have audio sound left only?Yes,mean ur tv have a 1 or 2 long boards that are call a LCD inverter boards are the causes and the problems.These 1 or 2 long LCD inverter boards only job are to provided the tv LCD screen panel for a backlight for the tv to have picture only.Tries websites like Shopjimmy.com,Ebay.com to buy a 1 or 2 the tv long LCD inverter boards for the replacement.
Sansui HDLCD3210... | Answered on Jul 04, 2014
Use the input select button; usually marked as AV/TV.
Sansui HDLCD3210... | Answered on Dec 25, 2013
Might have been a power spike that flashed channel memory. try rescanning for channels. And make sure physically that you antennas wiring is good and anywhere on it. post what you find good luck...
Check and replace the T"Con board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sansui HDLCD3210... | Answered on Sep 26, 2013
You can get a replacement, only within its warranty period.
You need to do a channel search to find active channels in your area. This is part of the initial set up process
Sansui HDLCD3210... | Answered on Apr 05, 2013
Sansui HDLCD3210 32 in. LCD TV Logo
114 questions posted
Popular Products
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
get rid line 14 tv built in vcr
  • Televison & Video
