20 Most Recent Samsung CLX-3175FN Color Laser All-in-One Printer Questions & Answers
What kind of printer, HP will pop a 50 code which means underheat or overheat. Usually fuser replacment solves these problems, I would not leave it on they tend to melt plastic covers above printer.....
Samsung... | Answered on Oct 11, 2019
I was not able to scan to the computer from the printer and I resolved the issue by selecting "Enable Scan from Device Pannel" in the "Scan to PC Setings" menu in the "Samsung Easy Printer Manager". Somehow, the default value for this option was "Disable" and my printer could not make the connection to the computer. After changing it to "Enable Scan from Device Pannel", I was able to scan the documents to my computer using the menu options from the printer pannel.
Samsung... | Answered on Jun 05, 2019
Hello, you can try this:
Press: Menu, #1934, Menu, "Tech Mode " OK, "Data Setup" OK, > x7 to "Clear Counts" OK, "Enter Password [1934]", OK, "Clear Counts [Total Page CNT]", >x3 to "[Imaging Unit]" OK, "Clearing...", back
Samsung... | Answered on Dec 29, 2017
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Samsung... | Answered on Jul 26, 2017
go to printer settings and select black and white only
however as the printer is running color cartridges and they are empty you will always get that message
it is not a good idea to run the printer with empty cartridges
Samsung... | Answered on Jan 20, 2016
I just replaced the fuser on this machine and the hardest part I think getting the right side cover off. The service manual was of little help the trick is to pry from the back and bottom. there are two little round tabs on the underside of the cover use a flat blade and pull. Once you remove the cover then I took the 4 screws out that hold the fuser. Then I lifted the fuser on the right side and traced the wires down to the board. There is a plastic piece on the right side of the fuser that sides into a gear. You have to slide to to the right to free the fuser. I used duct tape to keep the plastic piece and spring inside from falling out. Good Luck
Samsung... | Answered on Nov 06, 2015
You can use OCR, the dpi is high enough, you just need the OCR software on your computer. There are no brains in the printer to convert the images.
Samsung... | Answered on Oct 17, 2015
Dear
The printer paper jam-2 cover may be opened or not locked properly.
This door is at back side of the printer.
Thanks.
Samsung... | Answered on Mar 04, 2015
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
If it same - tries to print, motor running, and start work of mechanism but not printing may be it's problem of pick up roller, roller has rubber, it tired. replace rubber of roller or wipe it with sandpaper carefully
Samsung... | Answered on Dec 31, 2014
there is a chip on the new drum that is bad. you need to return it to whom ever you bought it and they should replace it.
Samsung... | Answered on Oct 23, 2014
I assume that you made some alternation to the printer the it sense the change and blow the resistor of the imaging unit.all you need to do is check the resistor by the side of the imaging unit if it is blown replace it with same value but a stronger one.
Samsung... | Answered on Oct 08, 2014
Press: Menu # 1 9 3 4 OK Menu
Tech Mode / Tech Menu should now be shown on screen
Samsung... | Answered on Oct 04, 2014
You can only do that if your printer has a feeder. If it only has a cover and a gloss top where you place 1 sheet at a time, you can only do one at a time.
Samsung... | Answered on Aug 27, 2014
Could be bad cartridge leaking. Drum is in the cartridge and if the drum wiper is not doing a clean wipe toner will drop onto paper. Take out cartridge and over a sheet of white paper tap the cartridge with you hand, if toner drops you have a leaking cartridge. Also could be fuser area, they get dirty and leave lines or the teflon coating wears through and leaves a line, depending how old this unit is.
Samsung... | Answered on Aug 19, 2014
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
404 questions posted
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
samsung clx 3175w horizontal lines
  • Office Equipment & Supplies
