20 Most Recent Craftsman 42 in. Deck 19.5hp Lawn Tractor Questions & Answers
If you guys can get me the make, model & serial number of your machines....I can get you a diagram for free and help you through it. www.nnyparts.com
Craftsman 42 in.... | Answered on May 24, 2019
Are you getting spark to the plug(s). Check with spark tester. Is fuel getting into the cylinder(s)? When it turns over, do you get a spit or backfire? If yes, check flywheel for key.
Craftsman 42 in.... | Answered on Oct 23, 2018
You need to unplug the 6 PRONGED CONNECTOR down by the foot rest plate on the right hand side. When you remove it, you may notice that 2 prongs are missing. That is because there is only supposed to be 4 connectors, so don't worry and think 2 connectors broke off. Just leave that disconnected and the brake/clutch will be disengaged from the engine to allow it to continue running AFTER YOU RELEASE THE BRAKE! :) Which is what you had a problem with, just like alot of us. I have a PT9000 series Craftsman with the 28 HP Kohler engine. I wish I could upload a pic, but you'll see it when you look at it. It is easy to get to, and you shouldn't need any tools unless it is seized on REAL good!. After I disconnected it, I started it, took off the brake, fired up the snow thrower attachment and was able to move it forwards and backwards.... Another issue that these are prone to is being able to run the engine, but the mower will not move forward or backwards (And YES it is NOT in Neutral! :-P) maybe another connector issue... LOL Soon nothing will be left connected except the starter switch at this rate!.. Anyways, Theres your fix!
Craftsman 42 in.... | Answered on Jun 25, 2018
contact Sears Parts Direct .com they can help you may be able to download a manual
Craftsman 42 in.... | Answered on Mar 21, 2018
try PartsTreeRepairClinic yhey may have a video
Craftsman 42 in.... | Answered on Mar 18, 2018
sounds like the cable may be binding up. or there is an obstruction under it. take it off clean it good and spray some lubricant on all the moving parts. that usually gets the moving again.
Craftsman 42 in.... | Answered on Feb 18, 2018
PartsTreeRepairClinic will help
Craftsman 42 in.... | Answered on Feb 07, 2018
Ask a "Mahindra" dealer. Look one up on your computer.
Craftsman 42 in.... | Answered on Jan 19, 2018
Trace the red wire from the ignition switch, the fuse should be connected to the cowl assembly.
Craftsman 42 in.... | Answered on Jan 18, 2018
Looks to be a 1993 model
Sounds like a loose belt check the tension spring if they ok check and see if belt is strectched
Craftsman 42 in.... | Answered on Dec 19, 2017
I would suspect the issue you are having is the belt. I would raise the front of the tractor not tip it on its side. The belt is pretty straightforward on install.
Craftsman 42 in.... | Answered on Dec 13, 2017
check wireing for a short in the circut has to be one somewhere
Craftsman 42 in.... | Answered on Dec 03, 2017
sounds like valves are out of adjustment. but since you just put a cable on it be sure it is on correctly and the belt releases the blades because if the belt is to tight it will not allow the engine to turn over past the compression stroke as you are saying.
Craftsman 42 in.... | Answered on Nov 26, 2017
Maybe one of the pressure switches is bad
Craftsman 42 in.... | Answered on Sep 20, 2017
white smoke is more than likely a water issue. Oil usually has a bluish tinge to it but is some cases, it could be white. Drain the gas a fill with fresh to try and eliminate the possibility of water in the gas. Watch the oil level to see if it changes after using the mower. it may take a few times but if it is burning oil, the spark plug will look "wet" and oil soaked, with possible black soot type build up.
Craftsman 42 in.... | Answered on Aug 22, 2017
You need to check the compression on the engine and also the timing. It could be a head gasket or valve that is bad.
Craftsman 42 in.... | Answered on Jul 16, 2017
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
1,292 questions posted
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
get belts
  • Garden
