20 Most Recent Samsung RS2630SH Side by Side Refrigerator Questions & Answers
Quick Guide:
http://downloadcenter.samsung.com/content/EM/200602/20060228102556328/EN/Main.html
User Manual:
http://downloadcenter.samsung.com/content/UM/200605/20060509094228828_DA68-01365A-1.0.PDF
Samsung RS2630SH... | Answered on Sep 12, 2019
Never buy a Samsung refrigerator, they ALL has designs issues.
Samsung RS2630SH... | Answered on Jun 25, 2019
Change your water filter, you should change your filter at least every year or it will start to grow bactria. If you still have the bypass (little plastic cap) you can us that in the mean time to get better water flow, it goes where the filter goes
Samsung RS2630SH... | Answered on Jun 09, 2019
Get in touch with Samsung about this product at: http://www.samsung.com/us/support/owners/product/RS2630SH
Samsung has probably encountered this problem before and can guide you in solving it.
Samsung RS2630SH... | Answered on Nov 14, 2018
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Samsung RS2630SH... | Answered on Nov 01, 2018
Sounds to me like your condensor fan is not running probably control board or motor itself
Samsung RS2630SH... | Answered on Jan 26, 2018
Hello Gopi Krishna,
Rather than enumerate the MANY MANY possibilities...
as simple as an ice BLOCKAGE ... or a DOOR switch...
Better ideas are also available on the following
PARTS-HOUSE assistance page...
Just keep in mind they would love
to sell lots of parts...
My first suggestion... would be to check your door closures... make sure your switches light and dark as you open & close the door...
Look through your freezer vents for a SOLID frost = trouble.
(not necessarily a bad thing... Fix = easy...
OPEN doors... power off: 3 days)
((watch-out for defrost over-flow))
http://www.appliancepartspros.com/parts-for-samsung-rs2630sh-xaa-0000.html
Samsung RS2630SH... | Answered on Jan 12, 2018
check the cold for what you want but the ideal settings would be 5 for the freezer and 37 for the fridge
freezer can be really cold but the fridge if too cold will freeze vegetables and lettuce
Samsung RS2630SH... | Answered on Jan 03, 2018
It sounds like the thyristor or temperature unit is malfunctioning have it checked out and replace it if faulty.
Samsung RS2630SH... | Answered on Jan 02, 2018
If the reset procedures don't stop the beeping and you are out of warranty, here is an easy fix:
1- (You can unplug the fridge just to be cautious, but not necessary.) Remove the control panel from the front of the fridge. Mine pulls straight out without removing any screws.
2- On the back of the control panel is a black, round device - the only thing that pokes through the back of the panel. This device is small, maybe 1/2" in diameter and the same deep. (if it won't pop off easily, remove the 4 screws to remove the back cover for easier access.)
3- You will see a thin round disk inside. This is the speaker. Remove this disk, press the black speaker cover back on and press the control panel back into the front of the fridge.
All the controls will continue to work as before, but NO BEEPS!
Yea!
Samsung RS2630SH... | Answered on Oct 21, 2017
2 years is much too short for starting problems with a refridgerator contact your dealer for a condition because of warranty on the repair you eventual will spend on it. Hidden defects are factory falts are there some holes for melting water are clogged inside the fridge somewhere
An ordinary refrigerator is made for a 17-year life span. like brands as Bosch Siemens Kuppersbusch easely have that lifetime but your dealer is the right point to get your service .
Samsung RS2630SH... | Answered on Aug 18, 2017
The cost for a service call is about $100 and then labor you may end up with a bill for over $500.00 USD
Samsung RS2630SH... | Answered on Jul 07, 2017
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Samsung RS2630SH... | Answered on Apr 23, 2017
Samsung RS2630SH Side by Side Refrigerator Logo
1,255 questions posted
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
fridge keeps beeping even though door
  • Refrigerators
