20 Most Recent Amazon Kindle Paperwhite Questions & Answers
Amazon kindle support toll free kindle number 855-293-0942 for Amazon kindle online help
Amazon Kindle... | Answered 2 days ago
From your Kindle device or free Kindle reading app:
  1. Open the Kindle Store.
  2. Access the Kindle Unlimited landing page:
    • Kindle eReaders: Select All Categories, and then select Kindle Unlimited.
    • Kindle Fire tablets: Select Kindle Unlimited.
    • Free Kindle reading apps: Select Kindle Unlimited.
  3. Select My Kindle Unlimited Books, and then Return.
From your computer:
  1. Visit Manage Your Content and Devices.
  2. From Your Content, use the drop-down menu to filter by Kindle Unlimited and then Books.
  3. Next to the book you want to return, select Actions, and then select Return this book.
Amazon Kindle... | Answered on Jun 01, 2019
Fire Kindle Echo Support
Amazon's site has excellent support & help for your Kindle device. Click the above link and select your device.
Hope this helps, Nik.
Amazon Kindle... | Answered on Oct 09, 2018
Kindle Paperwhite Support Call 1 800 586 9247 Kindle Techs Follow this link to easily get started with kindle
Amazon Kindle... | Answered on Sep 09, 2018
Yes, What Robert Moore1 said. Long touch on the book on the home page(s) and then select *Remove from device* .
Note: Adding a book to Kindle Paperwhite doesn't remove it from your Cloud. Your Cloud is your library. Only a copy of a book is downloaded to your Kindle. If you have another device such as an Android with the Kindle App installed you can still download the same book from the Cloud because it's always there.
Amazon Kindle... | Answered on May 17, 2018
If it is the Amazon.com account password then go online and change your password. If the device password then try the following:
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
Amazon Kindle... | Answered on Mar 16, 2018
It is so simple just connect the Kindle wifi with password. Sometime due to virus issue Kindle do not connect with the wifi For more you can ask for the Kindle Support Kindle Technical Support Registration 877 690 9305
Amazon Kindle... | Answered on Mar 14, 2018
then perhaps if you go to the correct website you can but it is not thru FIXYA.
Amazon Kindle... | Answered on Mar 13, 2018
No my wife has two kindles, both are registered to her. I do not know how she did it. Try calling here.
Klindle Customer Support - Toll Free 1(800)-(550)-(1391)‎
Amazon Kindle... | Answered on Mar 05, 2018
You really need to talk to Kindle support. Log on to Amazon. Your Account, Click and go to Manage, click. On left of screen you'll see Kindle Support, Click on Help Home. This should show your devices and a quick fix list. If your device is NOT there you may need to see about getting it registered. Under Quick fixes click on contact and follow the directions there. I usually send an email and request a call back. They are pretty fast so don't be driving while you wait.
Amazon Kindle... | Answered on Mar 03, 2018
First reaction is to reset the tablet. Second check if you still can logon with your ID on the Kindel Store. Then try to buy a book. When the error keeps coming back goto the support page from Amazon with the link here:
I assume you mean kindle books you order online (not from the kindle itself?)
They are delivered to your Kindle based on what you have registered on line, not to your email. Therefore changing your email address should not matter (at least directly).
When you say 'moved' - do you mean moved house physically (which does not matter at all) or moved to using a new kindle? Assuming you mean a new kindle, you need to
A) make sure the kindle is registered to your Amazon account: go to home screen, touch top of screen to bring up menu and then press the 'three lines button', select settings. There should be option to register (you will need email address and password - so you need to make sure your online Amazon account has correct email address registered! This is where email change might be causing problems, but can be updated online)
B) when you order books online you need to select the correct kindle to deliver to in the drop down box next to the order button (it might be called something like "Paul's Second kindle")
You can access all books you have ever bought (for this kindle or any other) on Kindle paper white by selecting 'cloud' when on the list of books at home screen.
Hope that helps, if not please reply and explain in more detail what you are doing and what happens / does not happen
Amazon Kindle... | Answered on Mar 01, 2018
If you got to the Amazon Kindle website (using a laptop or desktop is better because of the typing involved) and log in and re-register both devices to the same email and password they will automatically show up as two devices on your one Kindle account and you should be able to use them to share the books on your cloud. The way I understand it is if you have two different user ID's and passwords, you will have two different clouds.
Amazon Kindle... | Answered on Feb 24, 2018
Try with another charger. If this not resolve the problem you have broken charging connector, charging line or mother board problem.
Amazon Kindle... | Answered on Jan 05, 2018
Call customer service. They will be happy to assist you
Amazon Kindle... | Answered on Jul 20, 2017
It[s stuck somewhere in it's program. Best thing would be to contact help. It's free and they are really good.
You can reach Kindle Customer Support via phone or chat by clicking one of the links below:
To contact us via phone:
http://www.amazon.com/clicktocall
To contact us via chat:
http://www.amazon.com/clicktochat
Amazon Kindle... | Answered on Apr 09, 2017
Do you speak German or do you need to change language the kindle is using?
Have you set up and online account with amazon yet? If not it can be done at same time from your device. On first page you will see a line of icons at top of page, tap the one with 3 lines. This will give you a list. Tap settings; The next page will give you info on registration of the device and another choice is wi-fi set up. Just follow the directions. For further help:
Amazon Kindle Paperwhite Logo
770 questions posted
Popular Products
Top Amazon Tablets & eReaders Experts
Norman Worley
Miguel Luiz Martins
Poul Brinchs Larsen
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Amazon Tablets & eReaders
Most Popular Question
return kindle book kindle unlimited
  • Tablets & eReaders
